Introduzione
In this guide you will learn how to remove a keyboard safely. Before you begin this guide you should have all required materials and tools necessary to properly remove the keyboard.
Parti
Nessuna parte richiesta.
Unplug the AC adapter and all other auxiliary components from the laptop. Slide the battery lock tab away from the center of the laptop to unlock the battery.
  • Unplug the AC adapter and all other auxiliary components from the laptop.
  • Slide the battery lock tab away from the center of the laptop to unlock the battery.
Aggiungi Commento
Slide the battery release tab away from the center of the laptop and hold it. Lifting from the small notch between the two tabs, pull the battery out of the laptop.
  • Slide the battery release tab away from the center of the laptop and hold it.
  • Lifting from the small notch between the two tabs, pull the battery out of the laptop.
Aggiungi Commento
Unscrew the 4 highlighted screws with a PH1 screwdriver.
  • Unscrew the 4 highlighted screws with a PH1 screwdriver.
Aggiungi Commento
Orient the laptop so that the screen is open and facing you. Slide the plastic opening tool underneath the top edge of the black plastic insert. Pull it off and set aside.
  • Orient the laptop so that the screen is open and facing you.
  • Slide the plastic opening tool underneath the top edge of the black plastic insert.
  • Pull it off and set aside.
Aggiungi Commento
Remove the 2 PH1 screws. Lift the keyboard from the top being carful not to remove it fully. There is still a ribbon cable that connects the keyboard to the laptop.
  • Remove the 2 PH1 screws.
  • Lift the keyboard from the top being carful not to remove it fully. There is still a ribbon cable that connects the keyboard to the laptop.
Aggiungi Commento
Disconnect the keyboard ribbon cable and remove the keyboard from the laptop.
  • Disconnect the keyboard ribbon cable and remove the keyboard from the laptop.
Aggiungi Commento
Conclusione
Youlen
Membro da: 11/04/2013
19 Reputazione
2 Guide realizzate
Cal Poly, Team 17-5, Regan Spring 2013 Membro di Cal Poly, Team 17-5, Regan Spring 2013
CPSU-REGAN-S13S17G5
4 Membri
6 Guide realizzate
very useful. THANKS
ANDREAS - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 11
Tutti i Tempi: 2,077
