Introduzione
Removing the monitor allows for replacement or inspection of the screen.
Parti
Nessuna parte richiesta.
Locate the two sliding locks indicated in the photo.
  • Locate the two sliding locks indicated in the photo.
  • Slide the right lock (labeled "1") to the right. It will remain in the unlocked position.
  • Slide the left lock (labeled "2") to the left and hold it in place.
Aggiungi Commento
While holding the left lock, place your finger in the indentation next to the battery and lift the battery out.
  • While holding the left lock, place your finger in the indentation next to the battery and lift the battery out.
Aggiungi Commento
Remove the four screws indicated in the photos using a Phillips 00 Screwdriver. Left to right: 6mm button-head, 3mm flat-head, 6mm button-head, 6mm button-head. Remove the four screws indicated in the photos using a Phillips 00 Screwdriver. Left to right: 6mm button-head, 3mm flat-head, 6mm button-head, 6mm button-head. Remove the four screws indicated in the photos using a Phillips 00 Screwdriver. Left to right: 6mm button-head, 3mm flat-head, 6mm button-head, 6mm button-head.
  • Remove the four screws indicated in the photos using a Phillips 00 Screwdriver. Left to right: 6mm button-head, 3mm flat-head, 6mm button-head, 6mm button-head.
Aggiungi Commento
With your hands, grasp the speaker cover on the edge nearest to the screen.
  • With your hands, grasp the speaker cover on the edge nearest to the screen.
  • Pry the speaker cover upward.
Aggiungi Commento
Remove the speaker cover. Your laptop will look like this photo when the speaker cover has been removed.
  • Remove the speaker cover. Your laptop will look like this photo when the speaker cover has been removed.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Remove the two 4mm flat-head screws indicated in the photo.
  • Remove the two 4mm flat-head screws indicated in the photo.
Aggiungi Commento
Slightly lift and ease the keyboard forward, toward the screen, until the tabs clear the case.
  • Slightly lift and ease the keyboard forward, toward the screen, until the tabs clear the case.
  • When all the tabs are free, slowly lift the bottom of the keyboard while keeping the top of the keyboard angled down. Continue to carefully rotate the keyboard over until you can access the ribbon cable that is still connecting it to the computer.
Aggiungi Commento
The Ribbon Cable must be disconnected here to release the keyboard.
  • The Ribbon Cable must be disconnected here to release the keyboard.
  • Using a plastic splunger or the tip of your screwdriver gently push upward on the two black tabs securing the connection.
  • When the black plastic bar running across the cable is unseated you can slowly and carefully pull the ribbon cable free.
  • You can now lift and remove the keyboard.
Aggiungi Commento
Locate the gray wire on the right. Detach the white end by gently pulling each socket away from the other. Detach the white end by gently pulling each socket away from the other.
  • Locate the gray wire on the right.
  • Detach the white end by gently pulling each socket away from the other.
Aggiungi Commento
On the left, locate the black and white wires with gold tips on the end. Pull up on the wires to detach them.
  • On the left, locate the black and white wires with gold tips on the end.
  • Pull up on the wires to detach them.
Aggiungi Commento
Locate the thick tan cord on the left. Slide the tan cord as shown to detach it. Slide the tan cord as shown to detach it.
  • Locate the thick tan cord on the left.
  • Slide the tan cord as shown to detach it.
Aggiungi Commento
On the right, locate the thick black wire  with the white rectangular end. Pull up on it to detach it.
  • On the right, locate the thick black wire with the white rectangular end.
  • Pull up on it to detach it.
Aggiungi Commento
Remove the four 8mm button-head screws that are located in the top right (2) and top left corners (2) of the front cover. Use a Phillips 00 Screwdriver. Remove the four 8mm button-head screws that are located in the top right (2) and top left corners (2) of the front cover. Use a Phillips 00 Screwdriver. Remove the four 8mm button-head screws that are located in the top right (2) and top left corners (2) of the front cover. Use a Phillips 00 Screwdriver.
  • Remove the four 8mm button-head screws that are located in the top right (2) and top left corners (2) of the front cover. Use a Phillips 00 Screwdriver.
Aggiungi Commento
Once all the wires are detached and screws are removed, pull up on the monitor to remove it.
  • Once all the wires are detached and screws are removed, pull up on the monitor to remove it.
There were two additional screws on the back of the laptop I had to remove to get the screen off.
Dylan Carter - Replica
Conclusione
Cal Poly, Team 17-6, Regan Spring 2013 Membro di Cal Poly, Team 17-6, Regan Spring 2013
CPSU-REGAN-S13S17G6
5 Membri
11 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 17
Tutti i Tempi: 1,028
