Introduzione
This guide will help you replace Toshiba Satellite A105-S4284 RAM. RAM allows memory to be accessed directly in a random order. You might need to replace a RAM if your computer shuts down abruptly, your computer performance is low quality, or the computer fails to install new programs.
Make sure your computer is turned off and the computer is not plugged in. Turn your laptop upside down, and slide the right release tab outward.
  • Make sure your computer is turned off and the computer is not plugged in.
  • Turn your laptop upside down, and slide the right release tab outward.
  • Using you left hand, hold the left release tab towards the left side and then pull the battery out.
Aggiungi Commento
Loosen the screw located on the cover of the RAM using Phillips #1 screwdriver. You will not be able to remove the screw from the panel as it is designed to stay in the panel.
  • Loosen the screw located on the cover of the RAM using Phillips #1 screwdriver.
  • You will not be able to remove the screw from the panel as it is designed to stay in the panel.
Aggiungi Commento
With your fingers, carefully remove the middle panel by lifting the edge with the indent. With your fingers, carefully remove the middle panel by lifting the edge with the indent.
  • With your fingers, carefully remove the middle panel by lifting the edge with the indent.
Aggiungi Commento
Using your fingers, release the tabs on both ends of the RAM. Pull the RAM out. The other RAM is released in the same manner.
  • Using your fingers, release the tabs on both ends of the RAM.
  • Pull the RAM out.
  • The other RAM is released in the same manner.
Aggiungi Commento
Conclusione
pfedigan
Membro da: 12/04/2013
11 Reputazione
4 Guide realizzate
Cal Poly, Team 2-23, Maness Spring 2013 Membro di Cal Poly, Team 2-23, Maness Spring 2013
CPSU-MANESS-S13S2G23
4 Membri
5 Guide realizzate
how to remove a bios passcode off of a Toshiba Satellite a105 s4374 laptop
simeon cole - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,318
