Parti
Nessuna parte richiesta.
Make sure your computer is turned off and the computer is not plugged in. Turn your laptop upside down, and slide the right release tab outward.
  • Make sure your computer is turned off and the computer is not plugged in.
  • Turn your laptop upside down, and slide the right release tab outward.
  • Using you left hand, hold the left release tab towards the left side and then pull the battery out.
Aggiungi Commento
Flip the laptop over so it is rightside up, and open the laptop all the way so that the screen is horizontal.
  • Flip the laptop over so it is rightside up, and open the laptop all the way so that the screen is horizontal.
Aggiungi Commento
Using the plastic opening tool, pry off the panel above the keyboard, starting near the right front speaker. Use the plastic opening tool to pop off tabs along the length of this panel. This may feel like you're about to break something, but as long as you work your way down the panel and don't yank it out, the laptop will be fine.
  • Using the plastic opening tool, pry off the panel above the keyboard, starting near the right front speaker.
  • Use the plastic opening tool to pop off tabs along the length of this panel.
  • This may feel like you're about to break something, but as long as you work your way down the panel and don't yank it out, the laptop will be fine.
Aggiungi Commento
Unscrew the two 4.5 mm screws holding the keyboard on with the Phillips #1 screwdriver. Unscrew the two 4.5 mm screws holding the keyboard on with the Phillips #1 screwdriver.
  • Unscrew the two 4.5 mm screws holding the keyboard on with the Phillips #1 screwdriver.
Aggiungi Commento
Lift the keyboard gently from the side closest the screen. Pull out the ribbon connecting the keyboard to the laptop. Pull out the ribbon connecting the keyboard to the laptop.
  • Lift the keyboard gently from the side closest the screen.
  • Pull out the ribbon connecting the keyboard to the laptop.
Aggiungi Commento
Remove the upper half of laptop and place bottom half in the center of your workspace. Remove the one 2.00mm phillips screw. Remove the ribbon cable connecting the USB ports to the motherboard.
  • Remove the upper half of laptop and place bottom half in the center of your workspace.
  • Remove the one 2.00mm phillips screw.
  • Remove the ribbon cable connecting the USB ports to the motherboard.
Aggiungi Commento
Remove the two 2.5mm phillips screws holding the spring retainer for the heat sink. Remove the two 4.0mm phillips screws holding the fan in place. Remove the fan power connector.
  • Remove the two 2.5mm phillips screws holding the spring retainer for the heat sink.
  • Remove the two 4.0mm phillips screws holding the fan in place.
  • Remove the fan power connector.
Aggiungi Commento
Lift fan and heat sink out of case.
  • Lift fan and heat sink out of case.
Aggiungi Commento
Lift the power jack straight up and out of the slots that hold it in.
  • Lift the power jack straight up and out of the slots that hold it in.
Aggiungi Commento
Lift the motherboard out of the bottom case. Lift the motherboard out of the bottom case.
  • Lift the motherboard out of the bottom case.
Aggiungi Commento
Rotate the locking screw holding the CPU in, counter clockwise 180 degrees. Rotate the locking screw holding the CPU in, counter clockwise 180 degrees.
  • Rotate the locking screw holding the CPU in, counter clockwise 180 degrees.
Aggiungi Commento
Lift CPU straight out of place. Hold CPU by the sides so you do not damage the small pins. Hold CPU by the sides so you do not damage the small pins.
  • Lift CPU straight out of place.
  • Hold CPU by the sides so you do not damage the small pins.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
When I replaced the old battery by the new one ,a message "4 minute to full charge ".some one told me there is a process to do .what is this process???
salah_saleh59 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 79
Tutti i Tempi: 3,164
