Strumenti
Nessun attrezzo richiesto.
Parti
Nessuna parte richiesta.
Placing your finger on the raised grip, push the battery casing to the right. It will slide over.
  • Placing your finger on the raised grip, push the battery casing to the right. It will slide over.
Aggiungi Commento
Pull the battery casing gently out toward yourself, until you hear a clicking sound.
  • Pull the battery casing gently out toward yourself, until you hear a clicking sound.
  • The battery should pull out to about 2 inches.
Aggiungi Commento
Lift the battery casing out of the laptop.
  • Lift the battery casing out of the laptop.
Aggiungi Commento
Stick a spudger in one of the sides of the top panel. Lift slowly from one side to the other and it will pop off. Stick a spudger in one of the sides of the top panel. Lift slowly from one side to the other and it will pop off.
  • Stick a spudger in one of the sides of the top panel. Lift slowly from one side to the other and it will pop off.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Using an Phillips screwdriver, unscrew and remove two screws labeled B2.6. Using an Phillips screwdriver, unscrew and remove two screws labeled B2.6. Using an Phillips screwdriver, unscrew and remove two screws labeled B2.6.
  • Using an Phillips screwdriver, unscrew and remove two screws labeled B2.6.
Aggiungi Commento
Using your hands, lift keyboard up toward you, starting from the edge closest to the screen.
  • Using your hands, lift keyboard up toward you, starting from the edge closest to the screen.
  • The keyboard is still connected to the laptop by a ribbon. Place the keyboard gently on top of the trackpad, keys side down.
Aggiungi Commento
Find the white ribbon connector (where the keyboard is still attached to the rest of the laptop). Slide the white ribbon connector up and lift the ribbon out of it.
  • Find the white ribbon connector (where the keyboard is still attached to the rest of the laptop).
  • Slide the white ribbon connector up and lift the ribbon out of it.
Aggiungi Commento
Using a Phillips Screwdriver, unscrew and remove the one F4 screw closest to the center of the laptop.
  • Using a Phillips Screwdriver, unscrew and remove the one F4 screw closest to the center of the laptop.
  • This screw is underneath the battery casing, located on the bottom of the laptop directly under the trackpad.
Aggiungi Commento
Using your finger, lift off the plastic covering the trackpad by putting your finger underneath the plastic and pulling towards you. The plastic should just pop off.
  • Using your finger, lift off the plastic covering the trackpad by putting your finger underneath the plastic and pulling towards you. The plastic should just pop off.
Aggiungi Commento
Remove the left, brown ribbon by pinching the part of the ribbon connected to the computer and lifting towards you. Remove the left, brown ribbon by pinching the part of the ribbon connected to the computer and lifting towards you.
  • Remove the left, brown ribbon by pinching the part of the ribbon connected to the computer and lifting towards you.
Aggiungi Commento
Remove the white ribbon on the right by pinching the part connected to the laptop with your fingers and pulling towards you. Remove the white ribbon on the right by pinching the part connected to the laptop with your fingers and pulling towards you.
  • Remove the white ribbon on the right by pinching the part connected to the laptop with your fingers and pulling towards you.
Aggiungi Commento
Lift the track pad gently towards you, using your fingers.
  • Lift the track pad gently towards you, using your fingers.
Aggiungi Commento
Conclusione
Hannah
Membro da: 24/06/2010
209 Reputazione
7 Guide realizzate
Cal Poly, Team 3-5, Johann Summer 2010 Membro di Cal Poly, Team 3-5, Johann Summer 2010
CPSU-JOHANN-R10S3G5
4 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 14
Tutti i Tempi: 3,797
