Placing your finger on the raised grip, push the battery casing to the right. It will slide over.
  • Placing your finger on the raised grip, push the battery casing to the right. It will slide over.
Aggiungi Commento
Pull the battery casing gently out toward yourself, until you hear a clicking sound.
  • Pull the battery casing gently out toward yourself, until you hear a clicking sound.
  • The battery should pull out to about 2 inches.
Aggiungi Commento
Lift the battery casing out of the laptop.
  • Lift the battery casing out of the laptop.
Aggiungi Commento
Look at the bottom of the laptop. Using a Phillips screwdriver, unscrew and remove the screw labeled F4, located on the cover of the hard drive. The hard drive is located next to the CD drive.
  • Look at the bottom of the laptop. Using a Phillips screwdriver, unscrew and remove the screw labeled F4, located on the cover of the hard drive.
  • The hard drive is located next to the CD drive.
Aggiungi Commento
Placing your finger on the raised grip, push up on the hard drive cover. This will remove  the hard drive cover from the laptop.
  • Placing your finger on the raised grip, push up on the hard drive cover. This will remove the hard drive cover from the laptop.
Aggiungi Commento
Using a Phillips screwdriver, unscrew and remove the screw surrounded by the white plastic. Using a Phillips screwdriver, unscrew and remove the screw surrounded by the white plastic.
  • Using a Phillips screwdriver, unscrew and remove the screw surrounded by the white plastic.
Aggiungi Commento
Pull the white plastic out toward you. This should remove the hard drive tray from the laptop.
  • Pull the white plastic out toward you. This should remove the hard drive tray from the laptop.
  • This laptop does not have a hard drive, so the tray is empty. On your computer, the hard drive should be in the tray.
Aggiungi Commento
Stick a spudger in one of the sides of the top panel. Lift slowly from one side to the other and it will pop off. Stick a spudger in one of the sides of the top panel. Lift slowly from one side to the other and it will pop off.
  • Stick a spudger in one of the sides of the top panel. Lift slowly from one side to the other and it will pop off.
Aggiungi Commento
Using an Phillips screwdriver, unscrew and remove two screws labeled B2.6. Using an Phillips screwdriver, unscrew and remove two screws labeled B2.6. Using an Phillips screwdriver, unscrew and remove two screws labeled B2.6.
  • Using an Phillips screwdriver, unscrew and remove two screws labeled B2.6.
Aggiungi Commento
Using your hands, lift keyboard up toward you, starting from the edge closest to the screen.
  • Using your hands, lift keyboard up toward you, starting from the edge closest to the screen.
  • The keyboard is still connected to the laptop by a ribbon. Place the keyboard gently on top of the trackpad, keys side down.
Aggiungi Commento
Find the white ribbon connector (where the keyboard is still attached to the rest of the laptop). Slide the white ribbon connector up and lift the ribbon out of it.
  • Find the white ribbon connector (where the keyboard is still attached to the rest of the laptop).
  • Slide the white ribbon connector up and lift the ribbon out of it.
Aggiungi Commento
Using a Phillips Screwdriver, unscrew and remove the one F4 screw closest to the center of the laptop.
  • Using a Phillips Screwdriver, unscrew and remove the one F4 screw closest to the center of the laptop.
  • This screw is underneath the battery casing, located on the bottom of the laptop directly under the trackpad.
Aggiungi Commento
Using your finger, lift off the plastic covering the trackpad by putting your finger underneath the plastic and pulling towards you. The plastic should just pop off.
  • Using your finger, lift off the plastic covering the trackpad by putting your finger underneath the plastic and pulling towards you. The plastic should just pop off.
Aggiungi Commento
Remove the left, brown ribbon by pinching the part of the ribbon connected to the computer and lifting towards you. Remove the left, brown ribbon by pinching the part of the ribbon connected to the computer and lifting towards you.
  • Remove the left, brown ribbon by pinching the part of the ribbon connected to the computer and lifting towards you.
Aggiungi Commento
Remove the white ribbon on the right by pinching the part connected to the laptop with your fingers and pulling towards you. Remove the white ribbon on the right by pinching the part connected to the laptop with your fingers and pulling towards you.
  • Remove the white ribbon on the right by pinching the part connected to the laptop with your fingers and pulling towards you.
Aggiungi Commento
Lift the track pad gently towards you, using your fingers.
  • Lift the track pad gently towards you, using your fingers.
Aggiungi Commento
Using a Phillips screwdriver, unscrew and remove 5 screws labeled F6, located on the metal piece on the left side of the keyboard area. Using a Phillips screwdriver, unscrew and remove 5 screws labeled F6, located on the metal piece on the left side of the keyboard area. Using a Phillips screwdriver, unscrew and remove 5 screws labeled F6, located on the metal piece on the left side of the keyboard area.
  • Using a Phillips screwdriver, unscrew and remove 5 screws labeled F6, located on the metal piece on the left side of the keyboard area.
Aggiungi Commento
Using your fingers, pinch and lift metal piece away from the laptop and set aside.
  • Using your fingers, pinch and lift metal piece away from the laptop and set aside.
Aggiungi Commento
Using a Phillips screwdriver, unscrew and remove two screws labeled B25 located closest to the screen. Using a Phillips screwdriver, unscrew and remove two screws labeled B25 located closest to the screen.
  • Using a Phillips screwdriver, unscrew and remove two screws labeled B25 located closest to the screen.
Aggiungi Commento
Using a Phillips screwdriver, unscrew and remove two screws labeled B5.5, located to the right of where the metal piece was. These screws are silver, where all the other screws have been black.
  • Using a Phillips screwdriver, unscrew and remove two screws labeled B5.5, located to the right of where the metal piece was.
  • These screws are silver, where all the other screws have been black.
Aggiungi Commento
Using a Phillips screwdriver, unscrew and remove two black screws from the back side of the laptop. These screws are not labeled. These screws are not labeled.
  • Using a Phillips screwdriver, unscrew and remove two black screws from the back side of the laptop.
  • These screws are not labeled.
Aggiungi Commento
Using a Phillips screwdriver, unscrew and remove F4 screw from plastic covering on the bottom of the laptop that only has one screw.
  • Using a Phillips screwdriver, unscrew and remove F4 screw from plastic covering on the bottom of the laptop that only has one screw.
Aggiungi Commento
Using fingers,pinch and lift plastic covering up, away from the laptop and set aside. Using fingers,pinch and lift plastic covering up, away from the laptop and set aside.
  • Using fingers,pinch and lift plastic covering up, away from the laptop and set aside.
Aggiungi Commento
Using your fingers, pinch the black modem piece, lift and slide the modem up and move it aside. The modem is connected to a red and black wire.
  • Using your fingers, pinch the black modem piece, lift and slide the modem up and move it aside.
  • The modem is connected to a red and black wire.
Aggiungi Commento
Using a Phillips screwdriver, unscrew and remove one F6 screw from beneath the modem.
  • Using a Phillips screwdriver, unscrew and remove one F6 screw from beneath the modem.
Aggiungi Commento
Using a Phillips screwdriver, unscrew and remove 5 B20 screws, located along the corners of the bottom of the laptop. Using a Phillips screwdriver, unscrew and remove 5 B20 screws, located along the corners of the bottom of the laptop. Using a Phillips screwdriver, unscrew and remove 5 B20 screws, located along the corners of the bottom of the laptop.
  • Using a Phillips screwdriver, unscrew and remove 5 B20 screws, located along the corners of the bottom of the laptop.
Aggiungi Commento
Using a Phillips screwdriver, unscrew and remove 3 B25 screws from the bottom of the laptop. Using a Phillips screwdriver, unscrew and remove 3 B25 screws from the bottom of the laptop. Using a Phillips screwdriver, unscrew and remove 3 B25 screws from the bottom of the laptop.
  • Using a Phillips screwdriver, unscrew and remove 3 B25 screws from the bottom of the laptop.
Aggiungi Commento
Using a Phillips screwdriver, unscrew and remove 3 F6 screws from the bottom of the laptop. Using a Phillips screwdriver, unscrew and remove 3 F6 screws from the bottom of the laptop. Using a Phillips screwdriver, unscrew and remove 3 F6 screws from the bottom of the laptop.
  • Using a Phillips screwdriver, unscrew and remove 3 F6 screws from the bottom of the laptop.
Aggiungi Commento
Using a Phillips screwdriver, unscrew and remove 3 F4 screws from the battery area of the laptop. Using a Phillips screwdriver, unscrew and remove 3 F4 screws from the battery area of the laptop. Using a Phillips screwdriver, unscrew and remove 3 F4 screws from the battery area of the laptop.
  • Using a Phillips screwdriver, unscrew and remove 3 F4 screws from the battery area of the laptop.
Aggiungi Commento
Lift open the screen of the laptop and, using your fingers and the guides on the side of the laptop, push up on the top plastic covering of the laptop, moving from one side of the laptop to the other. Lift open the screen of the laptop and, using your fingers and the guides on the side of the laptop, push up on the top plastic covering of the laptop, moving from one side of the laptop to the other.
  • Lift open the screen of the laptop and, using your fingers and the guides on the side of the laptop, push up on the top plastic covering of the laptop, moving from one side of the laptop to the other.
Aggiungi Commento
Setting screen next to the base of the laptop, pinch the connecting cable with your fingers and gently pull connecting cable from monitor. Setting screen next to the base of the laptop, pinch the connecting cable with your fingers and gently pull connecting cable from monitor.
  • Setting screen next to the base of the laptop, pinch the connecting cable with your fingers and gently pull connecting cable from monitor.
Aggiungi Commento
Remove computer piece shown by pinching the plastic with your fingers and lifting it away from the laptop. Remove computer piece shown by pinching the plastic with your fingers and lifting it away from the laptop.
  • Remove computer piece shown by pinching the plastic with your fingers and lifting it away from the laptop.
Aggiungi Commento
Usning your fingers, slide the optical drive out of the laptop, towards you, and lift it out. Usning your fingers, slide the optical drive out of the laptop, towards you, and lift it out. Usning your fingers, slide the optical drive out of the laptop, towards you, and lift it out.
  • Usning your fingers, slide the optical drive out of the laptop, towards you, and lift it out.
Aggiungi Commento
Unscrew and remove single, silver T6 screw.
  • Unscrew and remove single, silver T6 screw.
Aggiungi Commento
Remove blue plastic piece by gently pulling away from adaptors on the back of the laptop.
  • Remove blue plastic piece by gently pulling away from adaptors on the back of the laptop.
Aggiungi Commento
Lift DC adaptor by sliding upwards out of the laptop and hold out of way. Lift DC adaptor by sliding upwards out of the laptop and hold out of way.
  • Lift DC adaptor by sliding upwards out of the laptop and hold out of way.
Aggiungi Commento
Remove from connector by gently pulling on white connector and cord. Remove from connector by gently pulling on white connector and cord. Remove from connector by gently pulling on white connector and cord.
  • Remove from connector by gently pulling on white connector and cord.
Aggiungi Commento
Conclusione
Altre 5 persone hanno completato questa guida.
Hannah
Membro da: 24/06/2010
209 Reputazione
7 Guide realizzate
Cal Poly, Team 3-5, Johann Summer 2010 Membro di Cal Poly, Team 3-5, Johann Summer 2010
CPSU-JOHANN-R10S3G5
4 Membri
8 Guide realizzate
thank you so much
akmal amil - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 2,821
