Introduzione
If your battery no longer holds charge, it is a wise decision to purchase a new battery and replace the old one. This guide will show you how to replace this battery.
Placing your finger on the raised grip, push the battery casing to the right. It will slide over.
  • Placing your finger on the raised grip, push the battery casing to the right. It will slide over.
Aggiungi Commento
Pull the battery casing gently out toward yourself, until you hear a clicking sound.
  • Pull the battery casing gently out toward yourself, until you hear a clicking sound.
  • The battery should pull out to about 2 inches.
Aggiungi Commento
Lift the battery casing out of the laptop.
  • Lift the battery casing out of the laptop.
Aggiungi Commento
Conclusione
Nathan
Membro da: 29/06/2010
104 Reputazione
1 Guida realizzata
Cal Poly, Team 3-5, Johann Summer 2010 Membro di Cal Poly, Team 3-5, Johann Summer 2010
CPSU-JOHANN-R10S3G5
4 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 4
Tutti i Tempi: 2,594
