Introduzione
Upgrading the RAM is a straightforward process that can significantly improve performance.
Two RAM slots allow up to 512MB of PC1600 DDR SDRAM.
Parti
Nessuna parte richiesta.
The RAM access panel is located near the middle of the bottom. The RAM access panel is located near the middle of the bottom.
  • The RAM access panel is located near the middle of the bottom.
Aggiungi Commento
Unscrew the single screw labeled F4 on the panel.
  • Unscrew the single screw labeled F4 on the panel.
Aggiungi Commento
Using a spudger, inserted into the notch under the screw hole, pry open and remove the cover.
  • Using a spudger, inserted into the notch under the screw hole, pry open and remove the cover.
Aggiungi Commento
Pull outward on each pair of restraining clips to free each chip. Pull outward on each pair of restraining clips to free each chip.
  • Pull outward on each pair of restraining clips to free each chip.
Aggiungi Commento
The RAM chips can now be pulled out. This laptop supports a maximum of two memory modules. The largest capacity for each is 256MB of PC1600 DDR SDRAM.
  • The RAM chips can now be pulled out.
  • This laptop supports a maximum of two memory modules. The largest capacity for each is 256MB of PC1600 DDR SDRAM.
Aggiungi Commento
Conclusione
Kiril Lange
Membro da: 22/09/2014
901 Reputazione
9 Guide realizzate
USF Tampa, Team 3-2, Brown Fall 2014 Membro di USF Tampa, Team 3-2, Brown Fall 2014
USFT-BROWN-F14S3G2
3 Membri
9 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 110
