Salta al contenuto principale
Toshiba SD-K740 Inverter Board Replacement
Cosa ti serve
  1. Toshiba SD-K740 Inverter Board Replacement, Top Panel: passo 1, immagine 1 di 1
    • Unplug the DVD player before beginning.
    • Remove the three 7.7 mm screws from the back panel using a Phillips #0 screwdriver.
  2. Toshiba SD-K740 Inverter Board Replacement: passo 2, immagine 1 di 2 Toshiba SD-K740 Inverter Board Replacement: passo 2, immagine 2 di 2
    • Turn the DVD player on its side.
    • Remove the 7.7 mm screw.
    • Flip the DVD player onto its other side.
  3. Toshiba SD-K740 Inverter Board Replacement: passo 3, immagine 1 di 1
    • Flip the DVD player over onto its front face.
    • Remove the back panel by lifting up and pulling it towards yourself.
  4. Toshiba SD-K740 Inverter Board Replacement, Front Panel: passo 4, immagine 1 di 1
    • Flip the DVD player so its top is sitting on your working surface.
    • Lift and push away the two tabs located in the middle of the player.
    • The front panel will not detach during this step, so do not force it.
  5. Toshiba SD-K740 Inverter Board Replacement: passo 5, immagine 1 di 1
    • Flip the DVD player on its side.
    • Lift and slide forward the single tab on the side.
  6. Toshiba SD-K740 Inverter Board Replacement: passo 6, immagine 1 di 2 Toshiba SD-K740 Inverter Board Replacement: passo 6, immagine 2 di 2
    • Grasp the front panel and pull forward to your right to remove it.
  7. Toshiba SD-K740 Inverter Board Replacement, Inverter Board: passo 7, immagine 1 di 1
    • Remove the black tie holding the two rear ribbon cables together by untwisting it.
  8. Toshiba SD-K740 Inverter Board Replacement: passo 8, immagine 1 di 2 Toshiba SD-K740 Inverter Board Replacement: passo 8, immagine 2 di 2
    • Remove the first of two ribbon cables connected to the motherboard by pulling vertically.
  9. Toshiba SD-K740 Inverter Board Replacement: passo 9, immagine 1 di 2 Toshiba SD-K740 Inverter Board Replacement: passo 9, immagine 2 di 2
    • Remove the second of two ribbon cables connected to the motherboard by pulling vertically.
  10. Toshiba SD-K740 Inverter Board Replacement: passo 10, immagine 1 di 1
    • Pull the two cables to the right to disentangle from the disc drive.
    • Do not tug, pull, or force cable, it should slide out with minimal force.
  11. Toshiba SD-K740 Inverter Board Replacement: passo 11, immagine 1 di 1
    • Pull power cord vertically to detach from the casing.
  12. Toshiba SD-K740 Inverter Board Replacement: passo 12, immagine 1 di 1
    • Remove the three .303 inch screws attaching the inverter board to the casing using a #0 Phillips screwdriver.
  13. Toshiba SD-K740 Inverter Board Replacement: passo 13, immagine 1 di 1
    • Push the inverter board forward and to the left to remove from the holding ledges.
  14. Toshiba SD-K740 Inverter Board Replacement: passo 14, immagine 1 di 2 Toshiba SD-K740 Inverter Board Replacement: passo 14, immagine 2 di 2
    • Lift the inverter board from the back end and pull toward you to complete removal.
Conclusione
Joe Murphy
Membro da: 01/20/11
542 Reputazione
5 Guide realizzate
Cal Poly, Team 1-16, Amido Winter 2011 Membro di Cal Poly, Team 1-16, Amido Winter 2011
CPSU-AMIDO-W11S1G16
4 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 2,098
