Introduzione
This guide gives instructions on how to remove the front panel of the Toshiba SD-K740 DVD player, a necessary step to access all parts for repair/replacement.
Parti
Nessuna parte richiesta.
Make sure the DVD player is unplugged before beginning.
  • Make sure the DVD player is unplugged before beginning.
  • Remove the three .303 inch screws from the back panel using a #0 Phillips head screwdriver.
Aggiungi Commento
Turn the DVD player on its side. Remove the .303 inch screw.
  • Turn the DVD player on its side.
  • Remove the .303 inch screw.
  • Now flip the DVD player onto its other side.
  • Remove the .303 inch screw from this side.
Aggiungi Commento
Flip the DVD player over onto it's front face.
  • Flip the DVD player over onto it's front face.
  • Remove the back panel by lifting up and pulling it towards yourself.
Aggiungi Commento
Flip the DVD player so its top is sitting on your working surface.
  • Flip the DVD player so its top is sitting on your working surface.
  • Lift and push away each of the two tabs located in the middle of the player.
  • The front panel will not come off during this step, so do not force it.
Aggiungi Commento
Flip the DVD player on its side.
  • Flip the DVD player on its side.
  • Lift and slide forward a single tab on the side.
Aggiungi Commento
Grasp the front panel and pull forward and to your right to remove. Grasp the front panel and pull forward and to your right to remove.
  • Grasp the front panel and pull forward and to your right to remove.
Aggiungi Commento
Conclusione
Joe Murphy
Membro da: 20/01/2011
542 Reputazione
5 Guide realizzate
Cal Poly, Team 1-16, Amido Winter 2011 Membro di Cal Poly, Team 1-16, Amido Winter 2011
CPSU-AMIDO-W11S1G16
4 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 403
