Introduzione
This guide gives instructions on how to remove the spring connected to the disc drive front flap of the Toshiba SD-K740 DVD player.
Parti
Nessuna parte richiesta.
Make sure the DVD player is unplugged before beginning.
  • Make sure the DVD player is unplugged before beginning.
  • Remove the three .303 inch screws from the back panel using a #0 Phillips head screwdriver.
Aggiungi Commento
Turn the DVD player on its side. Remove the .303 inch screw.
  • Turn the DVD player on its side.
  • Remove the .303 inch screw.
  • Now flip the DVD player onto its other side.
  • Remove the .303 inch screw from this side.
Aggiungi Commento
Flip the DVD player over onto it's front face.
  • Flip the DVD player over onto it's front face.
  • Remove the back panel by lifting up and pulling it towards yourself.
Aggiungi Commento
Flip the DVD player so its top is sitting on your working surface.
  • Flip the DVD player so its top is sitting on your working surface.
  • Lift and push away each of the two tabs located in the middle of the player.
  • The front panel will not come off during this step, so do not force it.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Flip the DVD player on its side.
  • Flip the DVD player on its side.
  • Lift and slide forward a single tab on the side.
Aggiungi Commento
Grasp the front panel and pull forward and to your right to remove. Grasp the front panel and pull forward and to your right to remove.
  • Grasp the front panel and pull forward and to your right to remove.
Aggiungi Commento
On back side of front panel very carefully apply pressure to the left hand side of the flap hinge. There is just enough tolerance in the plastic to allow removal, be careful of brittle plastic.
  • On back side of front panel very carefully apply pressure to the left hand side of the flap hinge.
  • There is just enough tolerance in the plastic to allow removal, be careful of brittle plastic.
Aggiungi Commento
Once the peg is free from the left restraint, carefully remove the left part of the flap.
  • Once the peg is free from the left restraint, carefully remove the left part of the flap.
  • Carefully remove the right peg from the restraint.
  • Do not pull away from the front panel because the spring is still attached.
  • Do not force the plastic.
Aggiungi Commento
Remove the spring from the end of the right peg by pulling the door away from the spring.
  • Remove the spring from the end of the right peg by pulling the door away from the spring.
  • Do not pull away from the front panel until the spring has been removed from the flap.
Aggiungi Commento
Remove the .384 inch screw holding the spring to front panel.
  • Remove the .384 inch screw holding the spring to front panel.
Aggiungi Commento
Slide the spring off of the underlying peg. Slide the spring off of the underlying peg.
  • Slide the spring off of the underlying peg.
Aggiungi Commento
Conclusione
John Lokker
Membro da: 20/01/2011
319 Reputazione
3 Guide realizzate
Cal Poly, Team 1-16, Amido Winter 2011 Membro di Cal Poly, Team 1-16, Amido Winter 2011
CPSU-AMIDO-W11S1G16
4 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 46
Tutti i Tempi: 4,147
