Salta al contenuto principale
Toshiba SD-K740 Front Flap Tray Door Replacement
Cosa ti serve
  1. Toshiba SD-K740 Front Flap Tray Door Replacement, Top Panel: passo 1, immagine 1 di 1
    • Unplug the DVD player before beginning.
    • Remove the three 7.7 mm screws from the back panel using a Phillips #0 screwdriver.
  2. Toshiba SD-K740 Front Flap Tray Door Replacement: passo 2, immagine 1 di 2 Toshiba SD-K740 Front Flap Tray Door Replacement: passo 2, immagine 2 di 2
    • Turn the DVD player on its side.
    • Remove the 7.7 mm screw.
    • Flip the DVD player onto its other side.
  3. Toshiba SD-K740 Front Flap Tray Door Replacement: passo 3, immagine 1 di 1
    • Flip the DVD player over onto its front face.
    • Remove the back panel by lifting up and pulling it towards yourself.
  4. Toshiba SD-K740 Front Flap Tray Door Replacement, Front Panel: passo 4, immagine 1 di 1
    • Flip the DVD player so its top is sitting on your working surface.
    • Lift and push away the two tabs located in the middle of the player.
    • The front panel will not detach during this step, so do not force it.
  5. Toshiba SD-K740 Front Flap Tray Door Replacement: passo 5, immagine 1 di 1
    • Flip the DVD player on its side.
    • Lift and slide forward the single tab on the side.
  6. Toshiba SD-K740 Front Flap Tray Door Replacement: passo 6, immagine 1 di 2 Toshiba SD-K740 Front Flap Tray Door Replacement: passo 6, immagine 2 di 2
    • Grasp the front panel and pull forward to your right to remove it.
  7. Toshiba SD-K740 Front Flap Tray Door Replacement, Front Flap Tray Door: passo 7, immagine 1 di 2 Toshiba SD-K740 Front Flap Tray Door Replacement, Front Flap Tray Door: passo 7, immagine 2 di 2
    • On back side of front panel very carefully apply pressure to the left hand side of the flap hinge.
    • There is just enough tolerance in the plastic to allow removal, be careful of brittle plastic.
  8. Toshiba SD-K740 Front Flap Tray Door Replacement: passo 8, immagine 1 di 1
    • Once the peg is free from the left restraint, carefully remove the left part of the flap.
    • Carefully remove the right peg from the restraint.
    • Do not pull away from the front panel because the spring is still attached.
    • Do not force the plastic.
  9. Toshiba SD-K740 Front Flap Tray Door Replacement: passo 9, immagine 1 di 1
    • Remove the spring from the end of the right peg by pulling the door away from the spring.
    • Do not pull away from the front panel until the spring has been removed from the flap.
Conclusione
John Lokker
Membro da: 01/20/11
324 Reputazione
3 Guide realizzate
Cal Poly, Team 1-16, Amido Winter 2011 Membro di Cal Poly, Team 1-16, Amido Winter 2011
CPSU-AMIDO-W11S1G16
4 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 13
Tutti i Tempi: 1,404
