Salta al contenuto principale
Toshiba Portege R500 Audio/USB Port Replacement
Cosa ti serve
  1. Toshiba Portege R500 Audio/USB Port Replacement, Battery: passo 1, immagine 1 di 2 Toshiba Portege R500 Audio/USB Port Replacement, Battery: passo 1, immagine 2 di 2
    • Make sure the device is off to prevent data loss.
    • Slide both latches to the unlocked position to release the battery.
    • Switch the latch on the right to reveal red. The latch on the left needs to be held.
    • Pull the battery toward you while holding the left latch.
  2. Toshiba Portege R500 Audio/USB Port Replacement, Audio/USB Port: passo 2, immagine 1 di 1
    • Remove the sixteen screws at the locations shown with the Phillips 00 screwdriver.
  3. Toshiba Portege R500 Audio/USB Port Replacement: passo 3, immagine 1 di 2 Toshiba Portege R500 Audio/USB Port Replacement: passo 3, immagine 2 di 2
    • Pull up on the back casing and remove it, revealing the audio/usb port.
  4. Toshiba Portege R500 Audio/USB Port Replacement: passo 4, immagine 1 di 1
    • Remove the single 4 mm screw holding the port in place with the Phillips 00 screwdriver.
  5. Toshiba Portege R500 Audio/USB Port Replacement: passo 5, immagine 1 di 1
    • Use the plastic opening tool to disconnect the port from its power source on the laptop. This will be the wire connector with the white connection.
  6. Toshiba Portege R500 Audio/USB Port Replacement: passo 6, immagine 1 di 1
    • Remove the ribbon cable from the port to free it from the laptop.
    • Be careful when reconnecting the ribbon cable, it can be difficult.
Conclusione
Altre 2 persone hanno completato questa guida.
JRJones
Membro da: 04/19/13
169 Reputazione
5 Guide realizzate
Cal Poly, Team 2-19, Maness Spring 2013 Membro di Cal Poly, Team 2-19, Maness Spring 2013
CPSU-MANESS-S13S2G19
3 Membri
15 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 998
