Introduzione
In this guide, you will learn how to disassemble the broken/damaged screen from the rest of the laptop, allowing you to replace it for a new one. This guide will also teach you what the proper and necessary tools are for this repair.
Using a plastic opening tool, remove all stickers covering the screws. Note: There are 6 locations; 2 at the top corners, 2 at the bottom corners, and 2 more at the bottom, towards the center of the screen.
  • Using a plastic opening tool, remove all stickers covering the screws.
  • Note: There are 6 locations; 2 at the top corners, 2 at the bottom corners, and 2 more at the bottom, towards the center of the screen.
Aggiungi Commento
Remove all six 3.8mm screws from the screen using a #1 Phillips screwdriver. Remove all six 3.8mm screws from the screen using a #1 Phillips screwdriver.
  • Remove all six 3.8mm screws from the screen using a #1 Phillips screwdriver.
Aggiungi Commento
With a plastic opening tool, prop the plastic panel up to separate it from the rest of the laptop. Slowly pull the plastic panel from the entire laptop.
  • With a plastic opening tool, prop the plastic panel up to separate it from the rest of the laptop.
  • Slowly pull the plastic panel from the entire laptop.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Remove the four 5 mm screws with a Phillips #1 screwdriver, each located at the four corners of the screen. Remove the four 5 mm screws with a Phillips #1 screwdriver, each located at the four corners of the screen.
  • Remove the four 5 mm screws with a Phillips #1 screwdriver, each located at the four corners of the screen.
Aggiungi Commento
Carefully lift up the screen from the rest of the laptop and let it lean towards you, as it is still attached to cords and other wirings. Remove all white tape that hold the cords and wirings together.
  • Carefully lift up the screen from the rest of the laptop and let it lean towards you, as it is still attached to cords and other wirings.
  • Remove all white tape that hold the cords and wirings together.
Aggiungi Commento
Note: Some parts need unplugging. Slowly and carefully unplug each of the components. Note: Some parts need unplugging. Slowly and carefully unplug each of the components.
  • Note: Some parts need unplugging. Slowly and carefully unplug each of the components.
Aggiungi Commento
At this point, the screen should be completely disconnected from the rest of the laptop.
  • At this point, the screen should be completely disconnected from the rest of the laptop.
Aggiungi Commento
Conclusione
Varsha Roopreddy
Membro da: 19/04/2013
1 Reputazione
4 Guide realizzate
Cal Poly, Team 4-17, Maness Spring 2013 Membro di Cal Poly, Team 4-17, Maness Spring 2013
CPSU-MANESS-S13S4G17
3 Membri
4 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,059
