Salta al contenuto principale
Toshiba Portege M400 CD/DVD Drive Replacement
Cosa ti serve
  1. Toshiba Portege M400 CD/DVD Drive Replacement, CD/DVD Drive: passo 1, immagine 1 di 1
    • Make sure your computer is securely latched and closed.
    • Locate the CD drive on the right side of your Toshiba Portege M400 laptop and find a small hole right next to the CD drive button.
  2. Toshiba Portege M400 CD/DVD Drive Replacement: passo 2, immagine 1 di 2 Toshiba Portege M400 CD/DVD Drive Replacement: passo 2, immagine 2 di 2
    • Using the tweezers, insert them into the small hole next to the CD drive button.
  3. Toshiba Portege M400 CD/DVD Drive Replacement: passo 3, immagine 1 di 2 Toshiba Portege M400 CD/DVD Drive Replacement: passo 3, immagine 2 di 2
    • Push the tweezers back into the hole and grab the CD drive door with the other tweezers' appendage.
    • Pull the CD door out carefully to remove the broken or jammed disk.
    • Note: If the CD door still does not open, move on to the next step to see how to remove the CD drive entirely.
  4. Toshiba Portege M400 CD/DVD Drive Replacement: passo 4, immagine 1 di 1
    • Flip the laptop over so its on its face.
  5. Toshiba Portege M400 CD/DVD Drive Replacement: passo 5, immagine 1 di 3 Toshiba Portege M400 CD/DVD Drive Replacement: passo 5, immagine 2 di 3 Toshiba Portege M400 CD/DVD Drive Replacement: passo 5, immagine 3 di 3
    • Locate screw as seen on picture
    • Using #1 Philips head screwdriver remove the 3.8mm screw.
  6. Toshiba Portege M400 CD/DVD Drive Replacement: passo 6, immagine 1 di 2 Toshiba Portege M400 CD/DVD Drive Replacement: passo 6, immagine 2 di 2
    • Locate the lock switch in the center of the laptop.
    • Locate the tab on the end of the end of the CD Drive.
  7. Toshiba Portege M400 CD/DVD Drive Replacement: passo 7, immagine 1 di 3 Toshiba Portege M400 CD/DVD Drive Replacement: passo 7, immagine 2 di 3 Toshiba Portege M400 CD/DVD Drive Replacement: passo 7, immagine 3 di 3
    • Push down on the lock tab and pull on the CD tab simultaneously.
    • Keep pulling on the CD drive tab until the CD drive comes all the way out.
Conclusione
Cal Poly, Team 4-17, Maness Fall 2012 Membro di Cal Poly, Team 4-17, Maness Fall 2012
CPSU-MANESS-F12S4G17
1 Membro
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 19
Tutti i Tempi: 1,113
