Introduzione
This guide will go through the steps needed to install a new wireless card.
Turn the computer over onto its back.
  • Turn the computer over onto its back.
Aggiungi Commento
Slide the lock on the left side to the unlock position. Slide the lock on the right side to the unlock position until there is a clicking sound.
  • Slide the lock on the left side to the unlock position.
  • Slide the lock on the right side to the unlock position until there is a clicking sound.
Aggiungi Commento
Remove the battery by sliding it out while both locks remain in the unlock position. Remove the battery by sliding it out while both locks remain in the unlock position.
  • Remove the battery by sliding it out while both locks remain in the unlock position.
Aggiungi Commento
Turn the computer onto the back. Remove the Phillips #0 screw that secures the cover to the rest of the device. One 5.1 mm coarse thread screw.
  • Turn the computer onto the back.
  • Remove the Phillips #0 screw that secures the cover to the rest of the device.
  • One 5.1 mm coarse thread screw.
  • Pull the cover forward to release it.
Aggiungi Commento
Use a Phillips #1 screwdriver to remove the two screws on opposite corners of the wireless card. Two 4.0 mm coarse thread screws. Use a plastic opening tool to gently lift the wireless card out while leaving the wire connected.
  • Use a Phillips #1 screwdriver to remove the two screws on opposite corners of the wireless card.
  • Two 4.0 mm coarse thread screws.
  • Use a plastic opening tool to gently lift the wireless card out while leaving the wire connected.
Aggiungi Commento
Hold the edges of the wireless card and carefully disconnect the black 3 pin connector. Hold the edges of the wireless card and carefully disconnect the black 3 pin connector.
  • Hold the edges of the wireless card and carefully disconnect the black 3 pin connector.
Aggiungi Commento
Conclusione
Alison Wendt
Membro da: 18/04/2013
78 Reputazione
6 Guide realizzate
Cal Poly, Team 21-51, Johann Spring 2013 Membro di Cal Poly, Team 21-51, Johann Spring 2013
CPSU-JOHANN-S13S21G51
3 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 540
