Start by first removing the battery. Move the first release switch to the right position.
  • Start by first removing the battery.
  • Move the first release switch to the right position.
  • Move the second release switch to the right position while pulling the battery towards the top of the netbook.
Aggiungi Commento
Using the bit driver and a Phillips #0 bit, remove the three circled screws, 5 mm in length.
  • Using the bit driver and a Phillips #0 bit, remove the three circled screws, 5 mm in length.
Aggiungi Commento
While holding the top of the netbook, flip the netbook over. While holding the top of the netbook, flip the netbook over.
  • While holding the top of the netbook, flip the netbook over.
Aggiungi Commento
Carefully lift off the power bar assembly for access to the button and receiver. Carefully lift off the power bar assembly for access to the button and receiver.
  • Carefully lift off the power bar assembly for access to the button and receiver.
Aggiungi Commento
Use the spudger to gently pry around the keyboard. This will release the keyboard assembly from the body. Use the spudger to gently pry around the keyboard. This will release the keyboard assembly from the body. Use the spudger to gently pry around the keyboard. This will release the keyboard assembly from the body.
  • Use the spudger to gently pry around the keyboard. This will release the keyboard assembly from the body.
Aggiungi Commento
Reach under the keyboard and disconnect the electrical connection. Lift the keyboard assembly out and away from the netbook.
  • Reach under the keyboard and disconnect the electrical connection.
  • Lift the keyboard assembly out and away from the netbook.
Aggiungi Commento
Remove the two noted screws, 5 mm in length, with a bit driver and Phillips 3/16" tool. Remove the two noted screws, 5 mm in length, with a bit driver and Phillips 3/16" tool.
  • Remove the two noted screws, 5 mm in length, with a bit driver and Phillips 3/16" tool.
Aggiungi Commento
Remove this electrical connection with tweezers. Use a spudger to gently pry the bezel from retaining clips.
  • Remove this electrical connection with tweezers.
  • Use a spudger to gently pry the bezel from retaining clips.
  • This will allow the keyboard bezel to lift off of the body.
Aggiungi Commento
Use tweezers to remove the electrical connection to the old speaker assembly.
  • Use tweezers to remove the electrical connection to the old speaker assembly.
Aggiungi Commento
Use a bit driver and a Phillips #0 bit to remove the two retaining screws on the speaker assembly. Lift out the old speaker assembly.
  • Use a bit driver and a Phillips #0 bit to remove the two retaining screws on the speaker assembly.
  • Lift out the old speaker assembly.
Aggiungi Commento
Conclusione
Mason McCaskill
Membro da: 18/10/2013
943 Reputazione
9 Guide realizzate
Clemson, Team 14-2, Benson Fall 2013 Membro di Clemson, Team 14-2, Benson Fall 2013
CLEM-BENSON-F13S14G2
3 Membri
9 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 324
