Introduzione
If the front facing camera on your Toshiba Excite 10 AT300 is now longer functioning, replacement isn't difficult and this guide will give you the step by step procedure. It involves removing a single copper foil wire.
Remove the SD card from the SD card slot.
  • Remove the SD card from the SD card slot.
Aggiungi Commento
Use the opening tool to separate the front and rear panels by slipping the tool underneath the screen edge and sliding it around the entire device. Make sure you unclip all of the clips on the back panel, or pulling it off will be difficult and may damage the tablet. Make sure you unclip all of the clips on the back panel, or pulling it off will be difficult and may damage the tablet.
  • Use the opening tool to separate the front and rear panels by slipping the tool underneath the screen edge and sliding it around the entire device.
  • Make sure you unclip all of the clips on the back panel, or pulling it off will be difficult and may damage the tablet.
Aggiungi Commento
Remove the speaker cable from its socket by gripping both sides of the white connector piece with tweezers and pulling straight out. Be careful not to rip the wires out of the white connector piece. Be careful not to rip the wires out of the white connector piece.
  • Remove the speaker cable from its socket by gripping both sides of the white connector piece with tweezers and pulling straight out.
  • Be careful not to rip the wires out of the white connector piece.
Aggiungi Commento
Using a #00 Phillips screwdriver, remove the following screws: Five 3mm Phillips #00 screws
  • Using a #00 Phillips screwdriver, remove the following screws:
    • Five 3mm Phillips #00 screws
Aggiungi Commento
Gently lift the battery, pulling away from the tab holding it in place at the bottom. While holding the battery up, use a pair of tweezers to remove the battery cable from its connector. While holding the battery up, use a pair of tweezers to remove the battery cable from its connector.
  • Gently lift the battery, pulling away from the tab holding it in place at the bottom.
  • While holding the battery up, use a pair of tweezers to remove the battery cable from its connector.
Aggiungi Commento
Using tweezers, pull the copper foil up from the back of the camera. It should peel up easily. Warning: Be careful to avoid ripping the foil.
  • Using tweezers, pull the copper foil up from the back of the camera. It should peel up easily.
    • Warning: Be careful to avoid ripping the foil.
Aggiungi Commento
Carefully remove the ribbon cable from the housing by pulling gently upwards on the sides of the cable housing. The cable should come straight up off of its housing.
  • Carefully remove the ribbon cable from the housing by pulling gently upwards on the sides of the cable housing. The cable should come straight up off of its housing.
Aggiungi Commento
Conclusione
Gus Holz
Membro da: 09/10/2014
297 Reputazione
2 Guide realizzate
Cal Poly, Team 14-26, Maness Fall 2014 Membro di Cal Poly, Team 14-26, Maness Fall 2014
CPSU-MANESS-F14S14G26
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 483
