Introduzione
The fix, I place a thin alloy shim between the existing heatsink & chip, with a good quality thermal paste, I always use artic silver 5(never lets you down)
This is a complete top half strip down to fix (takes me less than 30 minutes)
  • This is a complete top half strip down to fix (takes me less than 30 minutes)
Aggiungi Commento
this is the culprit, as you can see the shim can easily overheat & go concave lifting off the chip.
  • this is the culprit, as you can see the shim can easily overheat & go concave lifting off the chip.
Aggiungi Commento
cut  a  thin piece of alloy to the same size as the existing shim, i used an old alloy door push plate(easy to cut) & is the ideal thickness
  • cut a thin piece of alloy to the same size as the existing shim, i used an old alloy door push plate(easy to cut) & is the ideal thickness
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Thoroughly clean the chip with pure alcohol, then apply an even spread of good quality thermal paste(Arctic silver 5) will never let you down
  • Thoroughly clean the chip with pure alcohol, then apply an even spread of good quality thermal paste(Arctic silver 5) will never let you down
Aggiungi Commento
THen apply more thermal paste to the top of the shim
  • THen apply more thermal paste to the top of the shim
Aggiungi Commento
The new alloy shim is under the existing thin shim. I've done more than 20 of these repairs & had 100% success rate I always do the same to the CPU (might as well your already in there).,
  • The new alloy shim is under the existing thin shim. I've done more than 20 of these repairs & had 100% success rate I always do the same to the CPU (might as well your already in there).,
Aggiungi Commento
This is the CPU with the new alloy shim fitted.
  • This is the CPU with the new alloy shim fitted.
Aggiungi Commento
Conclusione
Terry Sim
Membro da: 12/02/2011
161 Reputazione
1 Guida realizzata
Pros: Very good hi-res pictures, well explained.
Cons: The disassembly instructions are missing
Nicola Nascimento - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 1,638
