Salta al contenuto principale
Toshiba Chromebook 2 Battery Replacement
Cosa ti serve
  1. Toshiba Chromebook 2 Battery Replacement, Back Cover: passo 1, immagine 1 di 1
    • Remove all external devices from the Toshiba Chromebook 2.
  2. Toshiba Chromebook 2 Battery Replacement: passo 2, immagine 1 di 1
    • Close the Toshiba Chromebook 2 and turn it over so that the bottom of the laptop is facing upwards toward you with the lettering on the bottom facing right side up.
  3. Toshiba Chromebook 2 Battery Replacement: passo 3, immagine 1 di 2 Toshiba Chromebook 2 Battery Replacement: passo 3, immagine 2 di 2
    • Remove the 8 visible Phillips 8.25 mm screws using the Phillips #0 screwdriver.
  4. Toshiba Chromebook 2 Battery Replacement: passo 4, immagine 1 di 2 Toshiba Chromebook 2 Battery Replacement: passo 4, immagine 2 di 2
    • Remove 2 hidden Phillips 8.25 mm screws located underneath the rubber grips at the back (opposite the hinges) with the Phillips #0 screwdriver.
    • The rubber grips are glued in place, so you'll need to peel them up with a spudger or other pry tool.
  5. Toshiba Chromebook 2 Battery Replacement: passo 5, immagine 1 di 1
    • Remove the back panel by pulling up on 2 adjacent corners.
  6. Toshiba Chromebook 2 Battery Replacement, Battery: passo 6, immagine 1 di 2 Toshiba Chromebook 2 Battery Replacement, Battery: passo 6, immagine 2 di 2
    • Remove the 4 Phillips 2 mm screws holding the battery in place with the Phillips #0 screwdriver.
  7. Toshiba Chromebook 2 Battery Replacement: passo 7, immagine 1 di 2 Toshiba Chromebook 2 Battery Replacement: passo 7, immagine 2 di 2
    • Press down on the white clip and softly pull the wires out of the port to disconnect battery from the motherboard.
  8. Toshiba Chromebook 2 Battery Replacement: passo 8, immagine 1 di 1
    • Remove the battery by gently pulling up on the bottom corners.
Conclusione
Altre 50 persone hanno completato questa guida.
Foster Chaney
Membro da: 10/08/15
762 Reputazione
1 Guida realizzata
IUPUI, Team 1-3, Hagerty Fall 2015 Membro di IUPUI, Team 1-3, Hagerty Fall 2015
IUPUI-HAGERTY-F15S1G3
5 Membri
7 Guide realizzate
7 Commenti
does the cb30-b-103 battery also work with the cb30-b-104 series?
henrikahlberg94 - Replica
I had four screws holding down battery.
When re-installing cover, don’t get confused. There are two holes under rubber feet on side CLOSEST TO HINGES. These do not accept the two screws - put them on side AWAY FROM HINGES.
Bill Brasier - Replica
Good instructions, my chrome is back to normal again .
Alexander Slaven - Replica
Many thanks but now there’s no curser! What do I do?
Chris in UK
Chris Tighe - Replica
Thank you, easy to follow, works like a dream
steve smith - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 37
Tutti i Tempi: 28,752
