Introduzione
Use this guide to replace your Toshiba AT1304T keypad
Using a thumb-tack, push-pin, or similar pin, remove the four plastic stoppers located on the back panel.
  • Using a thumb-tack, push-pin, or similar pin, remove the four plastic stoppers located on the back panel.
Aggiungi Commento
With the T8 Torx Security Bit Screwdriver, remove the four screws in the designated locations.
  • With the T8 Torx Security Bit Screwdriver, remove the four screws in the designated locations.
  • The T8 Torx Security Bit Screwdriver can be substituted with a small flathead screwdriver. Screw removal may be slightly more difficult however.
Aggiungi Commento
If needed, use the flathead screwdriver to gently pry the panel from the phone. Using your fingers, lift the panel from the device.
  • If needed, use the flathead screwdriver to gently pry the panel from the phone.
  • Using your fingers, lift the panel from the device.
Aggiungi Commento
Use your fingers to detach the ribbon wire located on the top of the logic board, as shown. Use your fingers to detach the ribbon wire located on the top of the logic board, as shown. Use your fingers to detach the ribbon wire located on the top of the logic board, as shown.
  • Use your fingers to detach the ribbon wire located on the top of the logic board, as shown.
Aggiungi Commento
Use a flathead screwdriver to gently pry the logic board and keypad from the device. Use a flathead screwdriver to gently pry the logic board and keypad from the device.
  • Use a flathead screwdriver to gently pry the logic board and keypad from the device.
Aggiungi Commento
Peel the keypad from the logic board using your thumb. Peel the keypad from the logic board using your thumb.
  • Peel the keypad from the logic board using your thumb.
Aggiungi Commento
Conclusione
Christopher
Membro da: 22/04/2010
90 Reputazione
16 Guide realizzate
Cal Poly, Team 16-6, Maness Spring 2010 Membro di Cal Poly, Team 16-6, Maness Spring 2010
CPSU-MANESS-S10S16G6
4 Membri
16 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,574
