Salta al contenuto principale
Toshiba A1304T Camera Replacement
Cosa ti serve
  1. Toshiba A1304T Camera Replacement, Back panel: passo 1, immagine 1 di 1
    • Using a thumb-tack, push-pin, or similar pin, remove the four plastic stoppers located on the back panel.
  2. Toshiba A1304T Camera Replacement: passo 2, immagine 1 di 1
    • With the T8 Torx Security Bit Screwdriver, remove the four screws in the designated locations.
    • The T8 Torx Security Bit Screwdriver can be substituted with a small flathead screwdriver. Screw removal may be slightly more difficult however.
  3. Toshiba A1304T Camera Replacement: passo 3, immagine 1 di 2 Toshiba A1304T Camera Replacement: passo 3, immagine 2 di 2
    • If needed, use the flathead screwdriver to gently pry the panel from the phone.
    • Using your fingers, lift the panel from the device.
  4. Toshiba A1304T Camera Replacement, Camera: passo 4, immagine 1 di 2 Toshiba A1304T Camera Replacement, Camera: passo 4, immagine 2 di 2
    • Using a small Phillips screwdriver, remove the two black screws from the positions indicated.
    • Gently pull the silver plate from the phone using your fingers.
  5. Toshiba A1304T Camera Replacement: passo 5, immagine 1 di 3 Toshiba A1304T Camera Replacement: passo 5, immagine 2 di 3 Toshiba A1304T Camera Replacement: passo 5, immagine 3 di 3
    • Using the head of a flathead screwdriver, flip the white segment of the socket that the camera's ribbon-wire runs into so that it is orientated vertically.
    • Gently lift the camera from its cavity and pull it away from the socket using your thumb and forefinger.
Conclusione
Christopher
Membro da: 04/22/10
90 Reputazione
8 Guide realizzate
Cal Poly, Team 16-6, Maness Spring 2010 Membro di Cal Poly, Team 16-6, Maness Spring 2010
CPSU-MANESS-S10S16G6
4 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 14
Tutti i Tempi: 2,068
