Peel back the sticker, using the tweezers on the bottom of the device to reveal the two screws.
  • Peel back the sticker, using the tweezers on the bottom of the device to reveal the two screws.
Aggiungi Commento
Unscrew the two T5 screws using the T5 Torx Screwdriver.
  • Unscrew the two T5 screws using the T5 Torx Screwdriver.
Aggiungi Commento
Insert the flat head screwdriver into the edge of the device. Using it as a lever, carefully pry the face-plate up.
  • Insert the flat head screwdriver into the edge of the device. Using it as a lever, carefully pry the face-plate up.
Aggiungi Commento
Carefully grab the ribbon cable with two fingers and pull the yellow ribbon cable upwards away from the motherboard.
  • Carefully grab the ribbon cable with two fingers and pull the yellow ribbon cable upwards away from the motherboard.
Aggiungi Commento
Remove the screen from of the face-plate.
  • Remove the screen from of the face-plate.
Aggiungi Commento
Insert the new screen into the face-plate.
  • Insert the new screen into the face-plate.
Aggiungi Commento
Reattach the yellow ribbon cable to the motherboard.
  • Reattach the yellow ribbon cable to the motherboard.
Aggiungi Commento
Using two hands, hold both ends of the device and snap the two plates together.
  • Using two hands, hold both ends of the device and snap the two plates together.
Aggiungi Commento
Re-insert the two T5 screws and tighten.
  • Re-insert the two T5 screws and tighten.
Aggiungi Commento
Re-apply the label edges back down to cover the screws.
  • Re-apply the label edges back down to cover the screws.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Mike Sollars
Membro da: 11/07/2013
471 Reputazione
3 Guide realizzate
WRI115, Team 1-1, Ruszkiewicz Spring 2013 Membro di WRI115, Team 1-1, Ruszkiewicz Spring 2013
WRI115-RUSZKIEWICZ-S13S1G1
4 Membri
3 Guide realizzate
Hi! Thanks for doing this. How do I release the yellow cable from the board?
Shaun B - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,302
