Introduzione
If your speakers have stopped working, this is the guide for you! It will show you how to replace your speaker with a new one.
Use a T-9 Torx screwdriver to unscrew the four screws on the back cover.
  • Use a T-9 Torx screwdriver to unscrew the four screws on the back cover.
Aggiungi Commento
Using the spudger, gently pry apart the back case from the front case. It is easier to start on a side and work your way around the device. Using the spudger, gently pry apart the back case from the front case. It is easier to start on a side and work your way around the device.
  • Using the spudger, gently pry apart the back case from the front case. It is easier to start on a side and work your way around the device.
Aggiungi Commento
Carefully pull the back cover apart from the front cover. Be careful not to pull too hard because there are two sets of wires connecting the device.
  • Carefully pull the back cover apart from the front cover. Be careful not to pull too hard because there are two sets of wires connecting the device.
Aggiungi Commento
Once the two covers are separated, use the tweezers, or even your fingers, to gently disconnect the two sets of wires that are connected to the motherboard from the back cover. You may have to wiggle the wires a little bit to get them to disconnect.
  • Once the two covers are separated, use the tweezers, or even your fingers, to gently disconnect the two sets of wires that are connected to the motherboard from the back cover. You may have to wiggle the wires a little bit to get them to disconnect.
Aggiungi Commento
Take the spudger and pry out the speaker. When taking out the speaker, the entire plastic shock mounting casing will come out.
  • Take the spudger and pry out the speaker.
  • When taking out the speaker, the entire plastic shock mounting casing will come out.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Becca
Membro da: 16/04/2010
202 Reputazione
2 Guide realizzate
Cal Poly, Team 7-7, Maness Spring 2010 Membro di Cal Poly, Team 7-7, Maness Spring 2010
CPSU-MANESS-S10S7G7
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 9,145
