Introduzione
Batteries do not last forever, so this guide is to show you how to replace the battery.
Use a T-9 Torx screwdriver to unscrew the four screws on the back cover.
  • Use a T-9 Torx screwdriver to unscrew the four screws on the back cover.
Aggiungi Commento
Using a spudger, gently pry apart the back case from the front case. It is easier to start on a side and work your way around the device. Using a spudger, gently pry apart the back case from the front case. It is easier to start on a side and work your way around the device.
  • Using a spudger, gently pry apart the back case from the front case. It is easier to start on a side and work your way around the device.
Aggiungi Commento
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Carefully pull the back cover apart from the front cover. Be careful not to pull too hard because there are two sets of wires connecting the device.
  • Carefully pull the back cover apart from the front cover. Be careful not to pull too hard because there are two sets of wires connecting the device.
Aggiungi Commento
Once the two covers are separated, use the tweezers, or even your fingers, to gently disconnect the two sets of wires that are connected to the motherboard from the back cover. You may have to wiggle the wires a little bit to get them to disconnect.
  • Once the two covers are separated, use the tweezers, or even your fingers, to gently disconnect the two sets of wires that are connected to the motherboard from the back cover. You may have to wiggle the wires a little bit to get them to disconnect.
Aggiungi Commento
Using the spudger, gently pry out the battery. The battery may seem tough to get out due to the adhesive used to secure it. Just slowly work at it and do not force anything.
  • Using the spudger, gently pry out the battery.
  • The battery may seem tough to get out due to the adhesive used to secure it. Just slowly work at it and do not force anything.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Trevor Foster
Membro da: 18/04/2010
142 Reputazione
3 Guide realizzate
Cal Poly, Team 7-7, Maness Spring 2010 Membro di Cal Poly, Team 7-7, Maness Spring 2010
CPSU-MANESS-S10S7G7
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 33
Tutti i Tempi: 9,153
