Introduzione
The back cover on the TomTom ONE is likely to chip or break due to excessive use. The mount guides can get worn down and not function properly. This guide will help you to replace it.
Use a T-9 Torx screwdriver to unscrew the four screws on the back cover.
  • Use a T-9 Torx screwdriver to unscrew the four screws on the back cover.
Aggiungi Commento
Using a spudger, gently pry apart the back case from the front case. It is easier to start on a side and work your way around the device. Using a spudger, gently pry apart the back case from the front case. It is easier to start on a side and work your way around the device.
  • Using a spudger, gently pry apart the back case from the front case. It is easier to start on a side and work your way around the device.
Aggiungi Commento
Carefully pull the back cover apart from the front cover. Be careful not to pull too hard because there are two sets of wires connecting the device.
  • Carefully pull the back cover apart from the front cover. Be careful not to pull too hard because there are two sets of wires connecting the device.
Aggiungi Commento
Once the two covers are separated, use tweezers, or even your fingers, to gently disconnect the two sets of wires that are connected to the motherboard from the back cover. You may have to wiggle the wires a little bit to get them to disconnect.
  • Once the two covers are separated, use tweezers, or even your fingers, to gently disconnect the two sets of wires that are connected to the motherboard from the back cover. You may have to wiggle the wires a little bit to get them to disconnect.
Aggiungi Commento
As you can see, the battery and the speaker are still attached to the device and must be removed.
  • As you can see, the battery and the speaker are still attached to the device and must be removed.
  • Using the spudger, carefully pry out both the battery and the speaker.
  • When taking out the speaker, the entire plastic shock mounting casing will come out.
  • The battery may seem tough to get out due to the adhesive used to secure it. Just slowly work at it and do not force anything.
Aggiungi Commento
Once the battery and the speaker are removed, you now only have the back cover!
  • Once the battery and the speaker are removed, you now only have the back cover!
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Trevor Foster
Membro da: 18/04/2010
142 Reputazione
3 Guide realizzate
Cal Poly, Team 7-7, Maness Spring 2010 Membro di Cal Poly, Team 7-7, Maness Spring 2010
CPSU-MANESS-S10S7G7
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 6,577
