Strumenti
Nessun attrezzo richiesto.
Parti
Does your Messenger Bag's cambuckle look like this? Well here's how to fix it! All you'll need is a new male cambuckle, which you can get from Timbuk2's customer service department. All you'll need is a new male cambuckle, which you can get from Timbuk2's customer service department.
Aggiungi Commento
Remove broken cam buckle. Un-thread strap from bottom plastic loop and take strap off. Remove broken cam buckle. Un-thread strap from bottom plastic loop and take strap off. Remove broken cam buckle. Un-thread strap from bottom plastic loop and take strap off.
  • Remove broken cam buckle. Un-thread strap from bottom plastic loop and take strap off.
Aggiungi Commento
Thread strap into new cam buckle through the buckle's top opening. Pull strap through the bottom of the buckle, ensuring that the strap goes in FRONT of the connectors as shown. Make sure the strap is not twisted or facing the wrong way when inserting the new cambuckle! Make sure the strap is not twisted or facing the wrong way when inserting the new cambuckle!
  • Thread strap into new cam buckle through the buckle's top opening. Pull strap through the bottom of the buckle, ensuring that the strap goes in FRONT of the connectors as shown.
  • Make sure the strap is not twisted or facing the wrong way when inserting the new cambuckle!
Aggiungi Commento
Snap buckle into female cam buckle and close the buckle.
  • Snap buckle into female cam buckle and close the buckle.
Aggiungi Commento
Thread strap through the bottom of the plastic loop (the loop where the strap was thread though before). Next, thread end of strap through the top end of plastic loop and pull to desired length.
  • Thread strap through the bottom of the plastic loop (the loop where the strap was thread though before).
  • Next, thread end of strap through the top end of plastic loop and pull to desired length.
Aggiungi Commento
Congrats! You're all done!
  • Congrats! You're all done!
Aggiungi Commento
Linea Traguardo
Emilee
Membro da: 13/03/2014
1.311 Reputazione
9 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 44
Tutti i Tempi: 2,499
