Salta al contenuto principale
TiVo Series 2 TCD540080 Cooling Fan Replacement
Cosa ti serve
  1. TiVo Series 2 TCD540080 Cooling Fan Replacement, Removal of TiVo Series 2 TCD540080 Case: passo 1, immagine 1 di 1
    • Power down the TiVo and detach the power cable from the rear of the unit.
    • Wait 5 minutes for the unit to fully discharge before proceeding to the next step.
  2. TiVo Series 2 TCD540080 Cooling Fan Replacement: passo 2, immagine 1 di 1
    • Remove the five T10 screws from the rear of the case using the Torx screwdriver.
  3. TiVo Series 2 TCD540080 Cooling Fan Replacement: passo 3, immagine 1 di 2 TiVo Series 2 TCD540080 Cooling Fan Replacement: passo 3, immagine 2 di 2
    • Lift up and pull back the outer casing towards the rear of the unit.
  4. TiVo Series 2 TCD540080 Cooling Fan Replacement, Cooling Fan: passo 4, immagine 1 di 1
    • The fan is held in by four T15 screws on the rear of the device.
  5. TiVo Series 2 TCD540080 Cooling Fan Replacement: passo 5, immagine 1 di 2 TiVo Series 2 TCD540080 Cooling Fan Replacement: passo 5, immagine 2 di 2
    • Take the wound red and black wires coming from the fan and follow them back to the logic board.
    • Unplug the connector from the motherboard.
  6. TiVo Series 2 TCD540080 Cooling Fan Replacement: passo 6, immagine 1 di 2 TiVo Series 2 TCD540080 Cooling Fan Replacement: passo 6, immagine 2 di 2
    • Pull the fan towards the front and out of the TiVo unit.
Conclusione
Cal Poly, Team 33-79, Johann Spring 2010 Membro di Cal Poly, Team 33-79, Johann Spring 2010
CPSU-JOHANN-S10S33G79
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 5,237
