Introduzione
The Motherboard contains all the 'brains' of the device. In case this component needs to be replaced, this guide will walk you through the installation of the motherboard.
Unscrew the five 0.31 inch T-9 screws on the back cover.
  • Unscrew the five 0.31 inch T-9 screws on the back cover.
Aggiungi Commento
Slide the cover towards the back until it is no longer under the front cover.
  • Slide the cover towards the back until it is no longer under the front cover.
Aggiungi Commento
Lift the cover up and off the device.
  • Lift the cover up and off the device.
Aggiungi Commento
Unscrew the 0.31 inch T-9 size screw on the back panel
  • Unscrew the 0.31 inch T-9 size screw on the back panel
  • Unscrew the two 0.59 inch T-8 size screws on the back panel
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Unplug the fan from the motherboard by gently pulling up on the red plug.
  • Unplug the fan from the motherboard by gently pulling up on the red plug.
Aggiungi Commento
Unplug the ribbon attaching the front panel sensor by pulling it upwards gently.
  • Unplug the ribbon attaching the front panel sensor by pulling it upwards gently.
Aggiungi Commento
Unplug the ribbon connecting the hard drive to the motherboard by pulling straight up on the ribbon. This may require some gentle wiggling.
  • Unplug the ribbon connecting the hard drive to the motherboard by pulling straight up on the ribbon. This may require some gentle wiggling.
Aggiungi Commento
Unplug the ribbon connecting the power supply to the motherboard by pulling upwards on this ribbon.
  • Unplug the ribbon connecting the power supply to the motherboard by pulling upwards on this ribbon.
Aggiungi Commento
Locate the four metal tabs on the motherboard. Using Pliers, bend each of the tabs until they align straight with the holes underneath them.
  • Locate the four metal tabs on the motherboard.
  • Using Pliers, bend each of the tabs until they align straight with the holes underneath them.
  • Bend these just enough to slip them through the holes. Over-bending could snap these tabs. While this won't affect how the TiVo functions, they are there to secure the motherboard to prevent damage.
Aggiungi Commento
Locate and remove the four 0.31 inch T-9 size screws at the front of the motherboard.
  • Locate and remove the four 0.31 inch T-9 size screws at the front of the motherboard.
Aggiungi Commento
Pull directly up on the motherboard so that it slips over the four golden metal tabs. Pull up and away from the back panel so all of the cable inputs slip through the casing.
  • Pull directly up on the motherboard so that it slips over the four golden metal tabs.
  • Pull up and away from the back panel so all of the cable inputs slip through the casing.
Aggiungi Commento
Conclusione
Cody Hunter
Membro da: 10/10/2011
22 Reputazione
2 Guide realizzate
Cal Poly, Team 5-33, Amido Fall 2011 Membro di Cal Poly, Team 5-33, Amido Fall 2011
CPSU-AMIDO-F11S5G33
4 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 960
