Introduzione
This guide will show how to remove the fan.
Parti
Nessuna parte richiesta.
Unscrew the five 0.31 inch T-9 screws on the back cover.
  • Unscrew the five 0.31 inch T-9 screws on the back cover.
Aggiungi Commento
Slide the cover towards the back until it is no longer under the front cover.
  • Slide the cover towards the back until it is no longer under the front cover.
Aggiungi Commento
Lift the cover up and off the device.
  • Lift the cover up and off the device.
Aggiungi Commento
Remove power cable to fan from motherboard.
  • Remove power cable to fan from motherboard.
Aggiungi Commento
Remove the four 0.31 inch T-9 screws and gently pull fan out. Remove the four 0.31 inch T-9 screws and gently pull fan out.
  • Remove the four 0.31 inch T-9 screws and gently pull fan out.
Aggiungi Commento
Conclusione
Talha
Membro da: 11/10/2011
31 Reputazione
2 Guide realizzate
Cal Poly, Team 5-33, Amido Fall 2011 Membro di Cal Poly, Team 5-33, Amido Fall 2011
CPSU-AMIDO-F11S5G33
4 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 547
