Introduzione
The battery acts as an internal power source for the device. In case this battery needs to be replaced, this simple guide will walk you through the steps of removing the current battery to replace it.
Parti
Nessuna parte richiesta.
Unscrew the five 0.31 inch T-9 screws on the back cover.
  • Unscrew the five 0.31 inch T-9 screws on the back cover.
Aggiungi Commento
Slide the cover towards the back until it is no longer under the front cover.
  • Slide the cover towards the back until it is no longer under the front cover.
Aggiungi Commento
Lift the cover up and off the device.
  • Lift the cover up and off the device.
Aggiungi Commento
Locate the battery on the motherboard.
  • Locate the battery on the motherboard.
Aggiungi Commento
Using the spudger, wedge the metal clip off of the top surface of the battery.
  • Using the spudger, wedge the metal clip off of the top surface of the battery.
Aggiungi Commento
Use your finger to push the battery sideways out of its holder.
  • Use your finger to push the battery sideways out of its holder.
Aggiungi Commento
Conclusione
Cody Hunter
Membro da: 10/10/2011
22 Reputazione
2 Guide realizzate
Cal Poly, Team 5-33, Amido Fall 2011 Membro di Cal Poly, Team 5-33, Amido Fall 2011
CPSU-AMIDO-F11S5G33
4 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 1,320
