Salta al contenuto principale
ThinkPad X1 Carbon SSD Replacement
Cosa ti serve
  1. ThinkPad X1 Carbon SSD Replacement, Remove Bottom Cover: passo 1, immagine 1 di 1
    • Use phillips #2 screwdriver to loosen seven cover screws.
    Chiedi a FixBot
    Aggiungi Commento
  2. ThinkPad X1 Carbon SSD Replacement, Remove Bottom Cover: passo 2, immagine 1 di 1
    • Use spudger to pop open bottom cover, remove and set aside.
    Chiedi a FixBot
    Aggiungi Commento
  3. ThinkPad X1 Carbon SSD Replacement, Disconnect Battery: passo 3, immagine 1 di 1
    • Disconnect the battery connector from the main board by pulling the connector towards the battery.
    Chiedi a FixBot
    Aggiungi Commento
  4. ThinkPad X1 Carbon SSD Replacement, Remove SSD Screw: passo 4, immagine 1 di 1
    • Use the # 2 phillips screwdriver and remove the screw holding the SSD in place.
    Chiedi a FixBot
    Aggiungi Commento
  5. ThinkPad X1 Carbon SSD Replacement, Remove SSD: passo 5, immagine 1 di 1
    • Remove the SSD by sliding it out of the connector to the right.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 12 persone hanno completato questa guida.
Mike
Membro da: 06/23/16
1.975 Reputazione
5 guide realizzate
iReconstruction Membro di iReconstruction
Business
Membro di 1
17 guide realizzate
8Commenti sulla guida
hi, can advise me which of the latest ssd 256/500 GB ssd's would work on a x1 carbon i5?
hardtail1969 - Rispondi Condividi
Really need to put the version/generation of the x1 carbon.. The gen 1 does not look like this inside and I’m spending way too much time trying to figure out what SSD it will take
Eric Metzger - Rispondi Condividi
Even for new models still can be used. same m.2 drive that might be located in the middle or top right of the device. Once the screws are off it is a very easy process.
jwalker8931 - Rispondi Condividi
I just replaced the SSD on my gen 6 and the steps are so easy: undo 5 screws, open up, undo 1 screw to loosen the M.2 module, replace and put things back together. There is no need to mess around with the battery connection at all.
haivu - Rispondi Condividi
A proper way, yes you need to disconnect the battery. You will learn it a hard way just a minor mistake, will blow your Mother Board and you will remember to disconnect them next time. The instruction is great.
Ryan Chau - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 8
Ultimi 7 giorni: 67
Ultimi 30 giorni: 293
Tutti i Tempi: 54,584
