Salta al contenuto principale
Texas Instruments TI-83 Plus Backup Battery Replacement
Cosa ti serve
  1. Texas Instruments TI-83 Plus Backup Battery Replacement, Backup Battery: passo 1, immagine 1 di 2 Texas Instruments TI-83 Plus Backup Battery Replacement, Backup Battery: passo 1, immagine 2 di 2
    • Remove the battery cover.
    • Remove the AAA batteries from the calculator.
  2. Texas Instruments TI-83 Plus Backup Battery Replacement: passo 2, immagine 1 di 1
    • Remove the 5mm Philips #00 screw holding backup battery cover.
    • Remove the backup battery cover.
  3. Texas Instruments TI-83 Plus Backup Battery Replacement: passo 3, immagine 1 di 1
    • Use plastic opening tool to remove the backup battery. Place the tool in the small cut-out next to the battery and pry the battery out.
    • Be careful, the backup battery is spring loaded and may shoot up when you remove it.
Conclusione
Clay
Membro da: 10/01/12
38 Reputazione
1 Guida realizzata
Cal Poly, Team 18-37, Regan Fall 2012 Membro di Cal Poly, Team 18-37, Regan Fall 2012
CPSU-REGAN-F12S18G37
5 Membri
5 Guide realizzate
Un commento
Will this wipe the memory?
John Osborne - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 81
Tutti i Tempi: 21,092
