Salta al contenuto principale
Technique - Test the Battery
Cosa ti serve
  1. Technique - Test the Battery, Technique - Test the Battery: passo 1, immagine 1 di 3 Technique - Test the Battery, Technique - Test the Battery: passo 1, immagine 2 di 3 Technique - Test the Battery, Technique - Test the Battery: passo 1, immagine 3 di 3
    • Remove back cover by applying pressure and sliding up towards the top of the phone.
  2. Technique - Test the Battery: passo 2, immagine 1 di 2 Technique - Test the Battery: passo 2, immagine 2 di 2
    • Remove the battery by lifting from slot on the right hand side.
  3. Technique - Test the Battery: passo 3, immagine 1 di 2 Technique - Test the Battery: passo 3, immagine 2 di 2
    • Use Multimeter to test the voltage of the battery.
    • Put the black lead into ground slot of multimeter and the red lead into the V(ohm)mA slot.
    • Place the red and black leads to the two outside metal plate, each on opposite sides, on the battery as shown.
    • Check that the voltage displayed on the multimeter matches closely to the voltage defined on the battery. Normally 3.7 V.
Conclusione
Melinda Phan
Membro da: 04/17/11
438 Reputazione
9 Guide realizzate
Cal Poly, Team 9-64, Walters Spring 2011 Membro di Cal Poly, Team 9-64, Walters Spring 2011
CPSU-WALTERS-S11S9G64
5 Membri
18 Guide realizzate
2 Commenti
Hello one the question was tablet not telephone and it's really vague how you guys explain these things you need to go to work on your site
Roger Slater - Replica
yes,not tablet with battery removal difficult
paulbeames7 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 34
Tutti i Tempi: 10,153
