Salta al contenuto principale
Tapwave T2907US Zodiac 2 Touchscreen/Display Replacement
Cosa ti serve
  1. Tapwave T2907US Zodiac 2 Touchscreen/Display Replacement, Back Cover: passo 1, immagine 1 di 1
    • Remove the four Torx T5 screws from the back panel.
  2. Tapwave T2907US Zodiac 2 Touchscreen/Display Replacement: passo 2, immagine 1 di 1
    • Wedge a spudger in between the front and back panel.
    • Apply leverage downwards to the spudger in order to remove the back panel.
  3. Tapwave T2907US Zodiac 2 Touchscreen/Display Replacement, Battery: passo 3, immagine 1 di 1
    • Slide the battery out from under the brown wire-tape.
    • Be careful of the wires still connected to the other end of the battery. Do not pull or damage may occur.
  4. Tapwave T2907US Zodiac 2 Touchscreen/Display Replacement: passo 4, immagine 1 di 1
    • Slowly pull the white plug from its receptor. Grasp its sides firmly with a pair of tweezers and gently wiggle from side to side.
  5. Tapwave T2907US Zodiac 2 Touchscreen/Display Replacement, Motherboard: passo 5, immagine 1 di 1
    • Unscrew the 2 Philips #00 screws on each end of the motherboard.
  6. Tapwave T2907US Zodiac 2 Touchscreen/Display Replacement: passo 6, immagine 1 di 1
    • Pull off the black memory card slot piece with tweezers.
  7. Tapwave T2907US Zodiac 2 Touchscreen/Display Replacement: passo 7, immagine 1 di 1
    • Unscrew the 2 Philips #00 screws on each side of the charging port.
  8. Tapwave T2907US Zodiac 2 Touchscreen/Display Replacement: passo 8, immagine 1 di 2 Tapwave T2907US Zodiac 2 Touchscreen/Display Replacement: passo 8, immagine 2 di 2
    • Disconnect 2 brown wire-tape ends from each end of the motherboard. Gently pull straight out with tweezers.
  9. Tapwave T2907US Zodiac 2 Touchscreen/Display Replacement: passo 9, immagine 1 di 1
    • Pull the motherboard and screen component diagonally up and left away from the auxiliary port entrance to remove.
    • Glue connecting the auxiliary port to the casing may make it difficult to remove. Gently apply force as needed.
  10. Tapwave T2907US Zodiac 2 Touchscreen/Display Replacement: passo 10, immagine 1 di 1
    • Disconnect the 2 brown wire-tape ends from the left side of the battery slot on the motherboard using tweezers.
  11. Tapwave T2907US Zodiac 2 Touchscreen/Display Replacement: passo 11, immagine 1 di 3 Tapwave T2907US Zodiac 2 Touchscreen/Display Replacement: passo 11, immagine 2 di 3 Tapwave T2907US Zodiac 2 Touchscreen/Display Replacement: passo 11, immagine 3 di 3
    • Disconnect the large brown wire-tape from the motherboard.
    • Peel the black tape back from the wire-tape using tweezers.
    • Lift the black, hinged, plastic lock with tweezers to release the wire-tape.
    • The screen and motherboard components can now be separated from each other.
  12. Tapwave T2907US Zodiac 2 Touchscreen/Display Replacement, Touchscreen/Display: passo 12, immagine 1 di 1
    • Unscrew the 2 Philips #00 screws from the bottom edge of the screen component.
  13. Tapwave T2907US Zodiac 2 Touchscreen/Display Replacement: passo 13, immagine 1 di 1
    • Take off the brown wire-tape from the small circuit board component.
    • Lift up so that the black plastic hinge piece swings open and the tape can be removed.
  14. Tapwave T2907US Zodiac 2 Touchscreen/Display Replacement: passo 14, immagine 1 di 3 Tapwave T2907US Zodiac 2 Touchscreen/Display Replacement: passo 14, immagine 2 di 3 Tapwave T2907US Zodiac 2 Touchscreen/Display Replacement: passo 14, immagine 3 di 3
    • Warning: If you are too rough with the screwdriver, you can permanently damage the display.
    • Use a Slot SL1.5 screwdriver to pry the touchscreen shell from the display component using the 4 slots around the entire component
Conclusione
Cal Poly, Team 10-33, Amido Winter 2012 Membro di Cal Poly, Team 10-33, Amido Winter 2012
CPSU-AMIDO-W12S10G33
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 901
