Introduzione
Use this repair guide when the shoulder buttons need to be replaced.
Remove the four Torx T5 screws from the back panel.
  • Remove the four Torx T5 screws from the back panel.
Aggiungi Commento
Wedge a spudger in between the front and back panel.
  • Wedge a spudger in between the front and back panel.
  • Apply leverage downwards to the spudger in order to remove the back panel.
Aggiungi Commento
Slide the battery out from under the brown wire-tape.
  • Slide the battery out from under the brown wire-tape.
    • Be careful of the wires still connected to the other end of the battery. Do not pull or damage may occur.
Aggiungi Commento
Slowly pull the white plug from its receptor. Grasp its sides firmly with a pair of tweezers and gently wiggle from side to side.
  • Slowly pull the white plug from its receptor. Grasp its sides firmly with a pair of tweezers and gently wiggle from side to side.
Aggiungi Commento
Unscrew the 2 Philips #00 screws on each end of the motherboard.
  • Unscrew the 2 Philips #00 screws on each end of the motherboard.
Aggiungi Commento
Pull off the black memory card slot piece with tweezers.
  • Pull off the black memory card slot piece with tweezers.
Aggiungi Commento
Unscrew the 2 Philips #00 screws on each side of the charging port.
  • Unscrew the 2 Philips #00 screws on each side of the charging port.
Aggiungi Commento
Disconnect 2 brown wire-tape ends from each end of the motherboard. Gently pull straight out with tweezers. Disconnect 2 brown wire-tape ends from each end of the motherboard. Gently pull straight out with tweezers.
  • Disconnect 2 brown wire-tape ends from each end of the motherboard. Gently pull straight out with tweezers.
Aggiungi Commento
Pull the motherboard and screen component diagonally up and left away from the auxiliary port entrance to remove.
  • Pull the motherboard and screen component diagonally up and left away from the auxiliary port entrance to remove.
  • Glue connecting the auxiliary port to the casing may make it difficult to remove. Gently apply force as needed.
Aggiungi Commento
Disconnect the 2 brown wire-tape ends from the left side of the battery slot on the motherboard using tweezers.
  • Disconnect the 2 brown wire-tape ends from the left side of the battery slot on the motherboard using tweezers.
Aggiungi Commento
Disconnect the large brown wire-tape from the motherboard. Peel the black tape back from the wire-tape using tweezers. Lift the black, hinged, plastic lock with tweezers to release the wire-tape.
  • Disconnect the large brown wire-tape from the motherboard.
    • Peel the black tape back from the wire-tape using tweezers.
    • Lift the black, hinged, plastic lock with tweezers to release the wire-tape.
    • The screen and motherboard components can now be separated from each other.
Aggiungi Commento
Carefully remove the solder between the shoulder buttons and the motherboard with the soldering sucker.
  • Carefully remove the solder between the shoulder buttons and the motherboard with the soldering sucker.
    • Try to avoid contact between the solder sucker and other components surrounding the shoulder buttons.
  • For more information on desoldering, look at this soldering/desoldering guide.
Aggiungi Commento
Conclusione
Daniel Wiseman
Membro da: 20/01/2012
127 Reputazione
6 Guide realizzate
Cal Poly, Team 10-33, Amido Winter 2012 Membro di Cal Poly, Team 10-33, Amido Winter 2012
CPSU-AMIDO-W12S10G33
4 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 499
