Salta al contenuto principale
TRS-80 Color Computer Keyboard Replacement
Cosa ti serve
  1. TRS-80 Color Computer Keyboard Replacement, Outside Casing: passo 1, immagine 1 di 1
    • Flip the computer over.
    • Remove the two 24.1mm Phillips screws near the front of the case.
    • Remove the five 33.0 mm Phillips screws towards the back of the case.
  2. TRS-80 Color Computer Keyboard Replacement: passo 2, immagine 1 di 2 TRS-80 Color Computer Keyboard Replacement: passo 2, immagine 2 di 2
    • Carefully flip the computer right side up.
    • Lift off the top half of the case.
  3. TRS-80 Color Computer Keyboard Replacement, Keyboard: passo 3, immagine 1 di 2 TRS-80 Color Computer Keyboard Replacement, Keyboard: passo 3, immagine 2 di 2
    • Near the motherboard, gently pull the keyboard ribbon cable until it becomes free.
    • Lift the keyboard out of the case.
Conclusione
Altre 3 persone hanno completato questa guida.
Cal Poly, Team 11-24, Maness Winter 2011 Membro di Cal Poly, Team 11-24, Maness Winter 2011
CPSU-MANESS-W11S11G24
4 Membri
10 Guide realizzate
Un commento
This only applies for Color Computers issued after the CoCo 1 F Board (as shown) RS catalog 26-3004 and subsequent models (CoCo 2 & 3). Early editions of the CoCo 1 had not a mylar ribbon cable like this but a heavier ribbon composed of actual wires, the connector they went into was also built for this type of ribbon. The keyboards on each category of connecting ribbon are sadly not interchangeable.
Rogelio Perea - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 16
Tutti i Tempi: 3,187
