Introduzione
Replace the cracked or damaged screen of TI-Nspire Calculator to enable the display for more efficient use of the device.
Place the calculator screen facing down with the back plate facing up.
  • Place the calculator screen facing down with the back plate facing up.
Aggiungi Commento
With a #000 Philips screwdriver, remove the 6 x .286 inch screw drivers located at the top, middle, and bottom of the calculator.
  • With a #000 Philips screwdriver, remove the 6 x .286 inch screw drivers located at the top, middle, and bottom of the calculator.
Aggiungi Commento
Locate the latch toward the bottom of the calculator.
  • Locate the latch toward the bottom of the calculator.
Aggiungi Commento
Slide the latch to the right to release the keypad. At the same time, pull the keypad down.
  • Slide the latch to the right to release the keypad.
  • At the same time, pull the keypad down.
Aggiungi Commento
Locate and remove the screw near the bottom of the calculator on the front side.
  • Locate and remove the screw near the bottom of the calculator on the front side.
    • The screw is behind where the keyboard normally sits.
Aggiungi Commento
Now, turn the calculator over so the back plate faces up. Use the Plastic Prying Tool to carefully pry the back plate out at the bottom right corner. The prying order is arbitrary. The important part is for it to be sequential across the length of the calculator.
  • Now, turn the calculator over so the back plate faces up.
  • Use the Plastic Prying Tool to carefully pry the back plate out at the bottom right corner.
    • The prying order is arbitrary. The important part is for it to be sequential across the length of the calculator.
  • Repeat the prying step on the right side, moving along the perimeter of the calculator.
  • Repeat the prying step on the top right corner.
Aggiungi Commento
Use your hands to manually separate the now loosened back plate from the calculator.
  • Use your hands to manually separate the now loosened back plate from the calculator.
Aggiungi Commento
Remove the four batteries to help prevent electrical shorts in later steps.
  • Remove the four batteries to help prevent electrical shorts in later steps.
Aggiungi Commento
Remove the four 0.165 inch screws at the middle and bottom of the motherboard with the screwdriver.
  • Remove the four 0.165 inch screws at the middle and bottom of the motherboard with the screwdriver.
  • Use a Phillips #000 screwdriver to remove the two 0.349 inch screws at the top corners of the motherboard.
Aggiungi Commento
Holding the calculator with the motherboard face-up, gently press the screen up about 3/8 inch and towards the motherboard. Remove the motherboard and screen together and set aside.
  • Holding the calculator with the motherboard face-up, gently press the screen up about 3/8 inch and towards the motherboard.
  • Remove the motherboard and screen together and set aside.
Aggiungi Commento
Use a flathead screwdriver to gently pry the orange ribbon away from the screen.
  • Use a flathead screwdriver to gently pry the orange ribbon away from the screen.
What is the purpose of step 11 since you have already taken the screen off the calculator?
Sarah Taylor - Replica
Conclusione
Alan Wong
Membro da: 26/09/2012
63 Reputazione
2 Guide realizzate
Cal Poly, Team 7-52, Forte Fall 2012 Membro di Cal Poly, Team 7-52, Forte Fall 2012
CPSU-FORTE-F12S7G52
5 Membri
11 Guide realizzate
Great guide! Just wondering where you found the replacement LCD? I've searched and searched the guide and the Internet and can't seem to locate them. Any help is greatly appreciated! Thanks!
Jeff Watkins - Replica
replacing is not easy. there are no quick connectors. used nspires r cheap.
trogfield - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 19
Tutti i Tempi: 5,692
