Introduzione
This guide is useful if the SIM card of the phone needs to be replaced or removed.
Strumenti
Nessun attrezzo richiesto.
Parti
Nessuna parte richiesta.
To remove the battery cover, first turn the phone so that the keypad is face down. While holding the phone with one hand, place the thumb of the other hand at the top of the battery cover. Slide the battery cover toward the bottom of the phone to remove.
  • To remove the battery cover, first turn the phone so that the keypad is face down.
  • While holding the phone with one hand, place the thumb of the other hand at the top of the battery cover.
  • Slide the battery cover toward the bottom of the phone to remove.
Aggiungi Commento
To remove the battery, first grab it using a finger on either side. Pull the battery upward, while securing the phone with your other hand.
  • To remove the battery, first grab it using a finger on either side.
  • Pull the battery upward, while securing the phone with your other hand.
  • Gently remove the battery and place it to the side of the phone.
Aggiungi Commento
Open the SIM card door, located on the lower right part of the phone. Insert the SIM card into the door with the gold plating facing downward. Close the SIM card door by lightly pushing downward.
  • Open the SIM card door, located on the lower right part of the phone.
  • Insert the SIM card into the door with the gold plating facing downward.
  • Close the SIM card door by lightly pushing downward.
Aggiungi Commento
Conclusione
Clemson, Team 15-4, Benson Fall 2012 Membro di Clemson, Team 15-4, Benson Fall 2012
CLEM-BENSON-F12S15G4
4 Membri
10 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 297
