Salta al contenuto principale
Surface Laptop Studio SSD Replacement
Cosa ti serve
  1. Surface Laptop Studio SSD Replacement, Lower Case: passo 1, immagine 1 di 1
    Strumento utilizzato in questo passaggio:
    • Remove the rubber cosmetic strip along the outside edge of the back plate with tweezers.
    Chiedi a FixBot
    Aggiungi Commento
  2. Surface Laptop Studio SSD Replacement: passo 2, immagine 1 di 2 Surface Laptop Studio SSD Replacement: passo 2, immagine 2 di 2
    • Use a hair dryer to lightly heat the rubber feet to soften the adhesive securing them to the case.
    • Remove the two rubber feet on the lower case with an opening tool.
    • If you intend to reuse the rubber feet, take care not to warp, stretch, or tear them during removal.
    Chiedi a FixBot
    Aggiungi Commento
  3. Surface Laptop Studio SSD Replacement: passo 3, immagine 1 di 1
    • Remove the two screws with a T3 Torx screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  4. Surface Laptop Studio SSD Replacement: passo 4, immagine 1 di 1
    • Remove the seven screws securing the lower case with a T3 Torx screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  5. Surface Laptop Studio SSD Replacement: passo 5, immagine 1 di 2 Surface Laptop Studio SSD Replacement: passo 5, immagine 2 di 2
    • Lift the lower case gently and set it above the device.
    • Take care not to strain the battery cable as you move the lower case.
    Chiedi a FixBot
    Aggiungi Commento
  6. Surface Laptop Studio SSD Replacement, Surface Laptop Studio Battery Disconnection: passo 6, immagine 1 di 2 Surface Laptop Studio SSD Replacement, Surface Laptop Studio Battery Disconnection: passo 6, immagine 2 di 2
    • Disconnect the battery cable by lifting the pull tab until it "clicks."
    Chiedi a FixBot
    Aggiungi Commento
  7. Surface Laptop Studio SSD Replacement, SSD: passo 7, immagine 1 di 1
    • After removing the devices battery, locate the SSD next to the mother board.
    Chiedi a FixBot
    Aggiungi Commento
  8. Surface Laptop Studio SSD Replacement: passo 8, immagine 1 di 1
    • Remove the single 3 mm screw that secures the SSD.
    Chiedi a FixBot
    Aggiungi Commento
  9. Surface Laptop Studio SSD Replacement: passo 9, immagine 1 di 1
    • Slide the SSD directly out of its socket.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 5 persone hanno completato questa guida.
5Commenti sulla guida
Is this strip tape or it metal? Is there replacements for it? I habe been trying to find it but I can only find tape as an alternative to this part.
Luis Ruiz - Rispondi Condividi
I tried the SSD upgrade with two different WD products (1TB black and 1TB blue) and with both I had problems: Random blue screens and after some time, computed could not find the SSD anymore. Looks like it has something to do with drive consuming too much power but I am not sure. I am now back on original 256 GB SSD, since I can't find what is causing compatibility issues.
Pohistvo123 - Rispondi Condividi
Can you fit a full sized ssd or only the short ones?
Omega_o7 - Rispondi Condividi
You can fit a full-size (M.2 2280) SSD in the Suface Laptop Studio, but you won't be reusing the metal bracket that is there for the small SDD (2230 size). More info available here: https://dancharblog.wordpress.com/2021/1...
DoktorDread - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 14
Ultimi 7 giorni: 59
Ultimi 30 giorni: 253
Tutti i Tempi: 14,700
