Introduzione
This guide will show you how to open up your Super Nintendo.
Parti
Nessuna parte richiesta.
Remove the six screws located on the underside of the system using the Gamebit 4.5mm screwdriver.
  • Remove the six screws located on the underside of the system using the Gamebit 4.5mm screwdriver.
In order to prevent damage to the fuse, make sure that you always cycle the power before doing so with the power supply disconnected.
Raucedine - Replica
There is a step missing from these instructions. There are two philips head screws where the AV/Power ports are on the back of the motherboard that need to be removed before you can remove the motherboard itself.
phoenixknight8082 - Replica
I replaced my controller port, thinking that it was the culprit, but my SNES is still having issues. Nothing works for controller port 1 and only a few buttons work for controller port 2. I tried switching out the controllers and the issue seems to be isolated to the SNES itself. Does anyone have any other suggestions for fixing my issue?
Thanks in advance.
Mike Watts - Replica
For those facing a black screen on startup (after having cleaned pins on cartridges and cartridge slot) WITH power light coming on, turn off console, remove power, and try shorting out the capacitor leads. My SNES stopped working suddenly after a single power cycle, and shorting out the leads (while UNPOWERED) revived it.
Austin Barnett - Replica
Could you further explain how to short the capacitor leads?
Will Pulman -
Carefully flip the unit back over. Locate the seam. Lift and separate the upper half of the case from the lower half of the case. Locate the seam. Lift and separate the upper half of the case from the lower half of the case.
  • Carefully flip the unit back over.
  • Locate the seam. Lift and separate the upper half of the case from the lower half of the case.
Aggiungi Commento
Conclusione
Altre 11 persone hanno completato questa guida.
Cameron Deines
Membro da: 05/10/2010
550 Reputazione
4 Guide realizzate
Cal Poly, Team 4-47, Amido Fall 2010 Membro di Cal Poly, Team 4-47, Amido Fall 2010
CPSU-AMIDO-F10S4G47
4 Membri
10 Guide realizzate
Hi, my name is Orlando, I'm writting of Perú, I have a question:
I can´t put the hinge of the top of that above part.
Please, can you help me, my mail is orla.davila12@gmail.com
Orlando Dávila Vizconde - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 49
Ultimi 30 Giorni: 169
Tutti i Tempi: 17,204
