Introduzione
This guide will show you how to remove the power switch connected to the motherboard. Steps can be followed in reverse to install a new power switch.
Cosa ti serve
Remove the six screws located on the underside of the system using the Gamebit 4.5mm screwdriver.
Remove the two 11.7 mm Phillips #2 screws connecting the power switch to the motherboard.
Altre 16 persone hanno completato questa guida.
2 Commenti
Any tips on how to tell if it's the power switch that needs replacing vs something else?
Look at it for any signs of physical damage, if you don't see any noticeable issues that you can fix then you can try cutting the two wires stripping off the ends of them, and very carefully touching the wires together while its plugged in. BE EXTREMELY CAREFUL WHILE DOING THIS DO NOT TOUCH THE EXPOSED WIRE. If you notice it turn on, immediately stop touching the wires together and unplug the console. This means that the switch itself is broken. If it doesn't turn on, stop touching the wire together and unplug the console. This means that it's likely a power cable issue.
