Introduzione
Use this guide to replace the seals on your device to prevent damages to the internal components.
Parti
Nessuna parte richiesta.
Place the lamp LED side down on a clean workspace.
  • Place the lamp LED side down on a clean workspace.
  • Remove the screws holding the casing together using a Phillips #1 Screwdriver.
Aggiungi Commento
Gently pull the two halves of the lamp apart.
  • Gently pull the two halves of the lamp apart.
Aggiungi Commento
On the clear upper half, remove the black O-ring Place the new O-ring, making sure it is smooth all the way around
  • On the clear upper half, remove the black O-ring
  • Place the new O-ring, making sure it is smooth all the way around
Aggiungi Commento
Remove the rubber stand holders.
  • Remove the rubber stand holders.
  • Place the new stand holders, making sure the wings of the holder are in the second opening
Aggiungi Commento
Conclusione
Josef Simek
Membro da: 23/10/2014
120 Reputazione
1 Guida realizzata
Michigan Tech, Team 1-3, Lauer Fall 2014 Membro di Michigan Tech, Team 1-3, Lauer Fall 2014
MTU-LAUER-F14S1G3
3 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 140
