Introduzione
The pump is used to take the water from the reservoir to the portafilter and steam wand.
Cosa ti serve
First remove all six screws on the back panel.
Remove the back panel, then set it aside.
Remove the two screws holding the bottom panel in place.
Remove the bottom panel, then set it aside.
Altre 15 persone hanno completato questa guida.
16 Commenti
My son and I successfully replaced the pump, but it didn't go quite as easily as I'd thought. We could not get the hose that connects the boiler to the pump off. Thankfully, my clever son realized we could turn the portion of the pump that screws into the t-end to get the old pump off and new one on.....tricky, but doable. The new pump is a bit noisier than the last, but she pulls beautiful shots. Thanks so much for this guide!
I put in a new pump and it still doesn’t work. I hear it him but can’t get it to pull water. I’ve tried the water in the line thing. How is the best way to prime it? Maybe that’s it?
Does anyone know the purpose of the hose that goes toward the back? not the one to the boiler but the other one that goes backward and down from the t-connector? it doesn't seem to be moving any water but the unit seems to work fine.
That's a return line I believe. So if there is water left it can drain back to the reservoir.
