Salta al contenuto principale
Stapler Maintenance
  1. Stapler Maintenance, Open & Identify: passo 1, immagine 1 di 2 Stapler Maintenance, Open & Identify: passo 1, immagine 2 di 2
    • Be careful while handling staples or any sharp object in general.
    • Grab the base of the stabler, and pull the hammer until the stapler opens, revealing the carrier, pusher, and spring.
    • Identify the staple type by looking on the bottom of the carrier. If the staple type is not on the carrier, look under the base.
  2. Stapler Maintenance, Insert Staples: passo 2, immagine 1 di 2 Stapler Maintenance, Insert Staples: passo 2, immagine 2 di 2
    • Get a cluster of staples and carefully place it in the carrier.
    • Make sure there is enough room for the pusher to contact the staples.
    • Close the stapler by clearing your hand from under the crimp area and pushing the hammer down until a clicking sound is heard.
  3. Stapler Maintenance: passo 3, immagine 1 di 1
    • Don’t staple your hand, or anyone else for that matter.
    • Congratulations! You have successfully replaced staples in your stapler.
Conclusione
Altre 7 persone hanno completato questa guida.
Un commento
Wnen I tried to load the staples, the spring came loose. But I do not know where to reconnect it and have a loose short plastic rod!
Brian Gray - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 16
Ultimi 7 Giorni: 207
Ultimi 30 Giorni: 633
Tutti i Tempi: 14,550
