Introduzione
If the user has already visited the troubleshooting page and has determine the issue incurred is due to a faulty micro SD card reader,and cleaning the reader has not worked, then this will be the guide to use.
Cosa ti serve
Remove the six silver 11.4 mm Phillips #0 screws
Pry open the device using a plastic opening tool if necessary. To do this, locate the groves running along the side of the entire device and wedge it open.
Now that your device is open, remove the Styrofoam pad that covers the main circuit board. The adhesive should allow you to remove and replace it with ease.
Remove the eight black 7.2 mm Phillips #0 screws from the top of the circuit board and remove the circuit board.
Unscrew the one 7.2 mm Phillips #0 screw from the plastic piece covering the microSD reader.
Then, unscrew the two 7.2 mm Phillips #0 screws from the microSD reader and remove it from its fastening.
On the back side of the reader there are nine wires. Un-solder these wires, remove the micro SD card reader, and solder on the replacement.
