Parti
Nessuna parte richiesta.
Flip the phone over so that the screen is facing down.
  • Flip the phone over so that the screen is facing down.
Aggiungi Commento
Push the gray lever up towards the top of the phone. Pull up on the battery pack and completely separate it from the phone.
  • Push the gray lever up towards the top of the phone.
  • Pull up on the battery pack and completely separate it from the phone.
Aggiungi Commento
Locate the 5 screws around the back casing. Use a three-prong screw bit to remove all 5 screws
  • Locate the 5 screws around the back casing.
  • Use a three-prong screw bit to remove all 5 screws
Aggiungi Commento
Use the plastic opening tool and slide it around the phone to pull apart the front and back casing.
  • Use the plastic opening tool and slide it around the phone to pull apart the front and back casing.
Aggiungi Commento
Separate the two cases.
  • Separate the two cases.
Aggiungi Commento
Use the plastic opening tool to remove the motherboard from the front case.
  • Use the plastic opening tool to remove the motherboard from the front case.
Aggiungi Commento
The plastic keys are attached to the back side of the front case. To remove the keys, pull the plastic piece out of the front case using the plastic opening tool.
  • The plastic keys are attached to the back side of the front case. To remove the keys, pull the plastic piece out of the front case using the plastic opening tool.
Aggiungi Commento
Conclusione
Katherine Rieck
Membro da: 18/10/2013
101 Reputazione
2 Guide realizzate
Clemson, Team 13-5, Benson Fall 2013 Membro di Clemson, Team 13-5, Benson Fall 2013
CLEM-BENSON-F13S13G5
3 Membri
12 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 63
