Salta al contenuto principale
Sony Xplod CDX-MP30 Front Screen Motherboard Replacement
Cosa ti serve
  1. Sony Xplod CDX-MP30 Front Screen Motherboard Replacement, Front Panel: passo 1, immagine 1 di 3 Sony Xplod CDX-MP30 Front Screen Motherboard Replacement, Front Panel: passo 1, immagine 2 di 3 Sony Xplod CDX-MP30 Front Screen Motherboard Replacement, Front Panel: passo 1, immagine 3 di 3
    • Press down the release button on the bottom left corner of the face plate.
    • Then remove the face plate carefully.
  2. Sony Xplod CDX-MP30 Front Screen Motherboard Replacement, Front Screen Motherboard: passo 2, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Phillips #0 Screwdriver
    $5.49
    Compra
  3. Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: passo 3, immagine 1 di 3 Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: passo 3, immagine 2 di 3 Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: passo 3, immagine 3 di 3
    • Use two fingers to create a small gap in the top of the faceplate, as indicated in the picture.
  4. Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: passo 4, immagine 1 di 3 Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: passo 4, immagine 2 di 3 Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: passo 4, immagine 3 di 3
    Heavy-Duty Spudger
    Compra
    • Insert the flat end of the Heavy-duty Spudger into the opening you created.
    • Slide it to the right carefully, until you feel the screen pop off.
    • Make sure you keep the face of the screen pointed down as you carefully lift off the freed black portion of the screen - as shown in the picture.
  5. Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: passo 5, immagine 1 di 2 Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: passo 5, immagine 2 di 2
    • Gently grab the Front Motherboard - as indicated in the picture - and lift it from the rest of the screen.
  6. Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: passo 6, immagine 1 di 1
    • To remove the LCD, please refer to the iFixit soldering guide.
    • Once the LCD screen is removed, you have unrestricted access to the front screen motherboard.
Conclusione
Chao Chen
Membro da: 10/04/11
79 Reputazione
5 Guide realizzate
Cal Poly, Team 5-35, Amido Fall 2011 Membro di Cal Poly, Team 5-35, Amido Fall 2011
CPSU-AMIDO-F11S5G35
4 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 22
Tutti i Tempi: 5,618
