Introduzione
A common problem occurring in the ZL is that the phone will sometimes attempt to draw significant current from the battery, immediately shutting down the phone. Replacing a worn battery with a new one should help to reduce this problem, even if only temporarily (and by temporarily this could mean any number of months)
BEFORE READING THIS GUIDE, please be aware that by removing the backing of this phone, you are essentially REMOVING THE MOISTURE SEALS protecting your phone. No more dumping this one in water unless you want to get out the silicone gun and have some fun with it
We will be removing components from the back of the phone; the battery is sandwiched between the motherboard and the screen so it's right in the middle of everything The service cover is easily visible from the back of the phone. There is an indentation to put a finger nail/spudger to pry upward There are 2 screws located underneath the label that shows where your sim card/microSD card go. Pry the label upwards to gain access.
  • We will be removing components from the back of the phone; the battery is sandwiched between the motherboard and the screen so it's right in the middle of everything
  • The service cover is easily visible from the back of the phone. There is an indentation to put a finger nail/spudger to pry upward
  • There are 2 screws located underneath the label that shows where your sim card/microSD card go. Pry the label upwards to gain access.
Aggiungi Commento
Remove the 2 #0 Philips screws securing the back of the case to the frame. The #0 screwdriver is the only one that will be needed for completion of this repair. BEFORE GOING FURTHER - Keep in mind that the ability to drop this phone in water (without ruining its internals) WILL BE LOST, as the gasket will definitely become warped or broken during its removal Start with your thinnest opening tool (mine happens to be a sharpened guitar pick) and insert it between the back casing and the frame. You should hear the sound of adhesive letting go.
  • Remove the 2 #0 Philips screws securing the back of the case to the frame. The #0 screwdriver is the only one that will be needed for completion of this repair.
  • BEFORE GOING FURTHER - Keep in mind that the ability to drop this phone in water (without ruining its internals) WILL BE LOST, as the gasket will definitely become warped or broken during its removal
  • Start with your thinnest opening tool (mine happens to be a sharpened guitar pick) and insert it between the back casing and the frame. You should hear the sound of adhesive letting go.
Aggiungi Commento
Use a heavier plastic opening tool or spudger inside the gap that you began to open up, sliding it further down each side of the case. You may find it easier to go in short steps, prying the rear case away from the frame slightly before advancing There are 3 plastic clips on one side and 2 on the other; in these areas you will have more resistance when sliding/prying. Slowly apply more pressure and they should release with a click
  • Use a heavier plastic opening tool or spudger inside the gap that you began to open up, sliding it further down each side of the case.
    • You may find it easier to go in short steps, prying the rear case away from the frame slightly before advancing
    • There are 3 plastic clips on one side and 2 on the other; in these areas you will have more resistance when sliding/prying. Slowly apply more pressure and they should release with a click
Aggiungi Commento
Take care not damaging the thin coating off the rear case as shown in the picture of the white version of the ZL. The notches of the rear case are shown in this picture
  • Take care not damaging the thin coating off the rear case as shown in the picture of the white version of the ZL.
  • The notches of the rear case are shown in this picture
Aggiungi Commento
Goodbye, rubber gasket - Because it won't be a uniform shape anymore, it is recommended to remove all remaining pieces of the foam/rubber seal
  • Goodbye, rubber gasket - Because it won't be a uniform shape anymore, it is recommended to remove all remaining pieces of the foam/rubber seal
    • Take your time, and make sure it is done properly. If you don't get it all, you may find that the phone back does not sit evenly against the frame
Aggiungi Commento
All of the ribbon cables listed will need to be removed - thankfully, they are all snap connectors, meaning they simply lift off of the motherboard to disconnect Removal of the top 4 snap connectors is straightforward - on the right side of each connector, insert a prying tool and pry upwards. The battery cable (right corner) requires slightly more force Look at picture 2 and 3 - bend the NFC antenna (thin black piece) upwards to reveal copper tape bridging the connector and the motherboard metal. Peel this up from the connector
  • All of the ribbon cables listed will need to be removed - thankfully, they are all snap connectors, meaning they simply lift off of the motherboard to disconnect
    • Removal of the top 4 snap connectors is straightforward - on the right side of each connector, insert a prying tool and pry upwards. The battery cable (right corner) requires slightly more force
    • Look at picture 2 and 3 - bend the NFC antenna (thin black piece) upwards to reveal copper tape bridging the connector and the motherboard metal. Peel this up from the connector
    • Straightforward removal, see top 4 (red) connectors
    • Pry from underneath where the wires are. Shouldn't take too much force, but it is small and likely brittle so be careful
Aggiungi Commento
Remove the 2 screws that secure the charging port bracket (silver clip shown) Remove metal bracket by lifting from circuitry-side (as shown). There is mild adhesive securing it to the charging port; don't be surprised if additional force is needed Remove the black screw located just underneath the rear-facing camera
  • Remove the 2 screws that secure the charging port bracket (silver clip shown)
  • Remove metal bracket by lifting from circuitry-side (as shown). There is mild adhesive securing it to the charging port; don't be surprised if additional force is needed
  • Remove the black screw located just underneath the rear-facing camera
Aggiungi Commento
The two screws on the left side of the motherboard are not the same size, so for organizational purposes: Remove this one first
  • The two screws on the left side of the motherboard are not the same size, so for organizational purposes:
    • Remove this one first
    • And then this one
  • The last screw is located on the bottom of the motherboard
Aggiungi Commento
This step involves removal of the top camera and speaker module. Read the next two steps before starting, as it is easy to rip one ribbon cable if you pry the part too far Insert your spudger as shown. This will involve some pressure, but the right side of the module should begin to lift from the frame My hand was covering the exact entry point, but you will want to further separate the module from the top left side of the phone (I'm holding it upside down)
  • This step involves removal of the top camera and speaker module. Read the next two steps before starting, as it is easy to rip one ribbon cable if you pry the part too far
  • Insert your spudger as shown. This will involve some pressure, but the right side of the module should begin to lift from the frame
  • My hand was covering the exact entry point, but you will want to further separate the module from the top left side of the phone (I'm holding it upside down)
  • Be very careful when lifting from the third spot - you only want to separate the clips on the side, if you lift the entire piece out of the phone, you can easily rip a ribbon cable underneath the assembly. See the next step for directions on how to fully remove the module
Aggiungi Commento
The top-left flex cable is the culprit for the added difficulty of fully separating the two pieces. But, since the adhesive is relatively small (see 2nd photo), by lifting the connector at a 90 degree angle away from the phone at a slow, steady pace, it should disconnect without damaging either cable Notice how much adhesive is holding the ribbon cable against the phone, but do not judge its effect by its size, or you may lose some critical phone functions! This is the flex cable that is likely to tear if you are not careful when removing the connectors from the adhesive. I believe it is the proximity sensor cable, which turns the screen off when you have your face close to the phone (during a phone call)
  • The top-left flex cable is the culprit for the added difficulty of fully separating the two pieces. But, since the adhesive is relatively small (see 2nd photo), by lifting the connector at a 90 degree angle away from the phone at a slow, steady pace, it should disconnect without damaging either cable
    • Notice how much adhesive is holding the ribbon cable against the phone, but do not judge its effect by its size, or you may lose some critical phone functions!
    • This is the flex cable that is likely to tear if you are not careful when removing the connectors from the adhesive. I believe it is the proximity sensor cable, which turns the screen off when you have your face close to the phone (during a phone call)
podria facilitarme el diagrama de del sensor que va integrado a la placa las resistencias que van debajo!?
enriqu33s - Replica
We are now free to remove the motherboard. Start by prying from the left side of the phone, making sure that none of the ribbon cables are catching on the motherboard as it is lifted The goal is to lift the motherboard to roughly a 45-degree angle on this side, as the charging port needs to be inserted and removed on an angle (see photo 2) Although I chose to start lifting from closer to the top of the motherboard, there are no physical components on the back, so damage is unlikely as long as you're careful (see photo 3)
  • We are now free to remove the motherboard. Start by prying from the left side of the phone, making sure that none of the ribbon cables are catching on the motherboard as it is lifted
    • The goal is to lift the motherboard to roughly a 45-degree angle on this side, as the charging port needs to be inserted and removed on an angle (see photo 2)
    • Although I chose to start lifting from closer to the top of the motherboard, there are no physical components on the back, so damage is unlikely as long as you're careful (see photo 3)
Aggiungi Commento
The battery is in sight! - keep in mind that without a heat gun (or very least hair dryer), this step will be impossible, as the adhesive that secures the battery to the back of the phone is very strong Before removing the battery, make sure that the two ends connecting the battery to the frame have been disconnected from the frame
  • The battery is in sight! - keep in mind that without a heat gun (or very least hair dryer), this step will be impossible, as the adhesive that secures the battery to the back of the phone is very strong
  • Before removing the battery, make sure that the two ends connecting the battery to the frame have been disconnected from the frame
    • I found it easiest to remove by getting in between the gap with some tweezers and pulling the tape up so that it disconnects.
    • You can keep the majority of the tape on the battery untouched, but eventually you will have to take it completely off the old battery and transfer onto the new one.
Aggiungi Commento
The objective is to remove the battery with the least amount of stress possible. Although it may not be likely on its own, bending lithium-polymer batteries will break their internal seals, and CAN EVEN CAUSE THEM TO EXPLODE!
  • The objective is to remove the battery with the least amount of stress possible. Although it may not be likely on its own, bending lithium-polymer batteries will break their internal seals, and CAN EVEN CAUSE THEM TO EXPLODE!
  • I will not be held liable for anyone's attempt on completing this step, or any others for that matter. It is AT YOUR OWN RISK
  • With that in mind, on medium heat and constantly moving around the entire pad of the battery, heat the area for roughly a minute, or until it is hot to the touch
Aggiungi Commento
While the phone is still warm/hot (and don't burn your hands), insert a guitar pick/opening tool underneath the battery around the top. some force will be needed If all is going well, you will hear the sound of adhesive releasing and your opening device will slide further underneath If you've made it this far underneath the battery, the temperature has likely cooled down significantly. So, keeping the opening tool inside, you'll be heating the battery again. This may deform your opening tool if it is made of plastic, so use your least-favorite one
  • While the phone is still warm/hot (and don't burn your hands), insert a guitar pick/opening tool underneath the battery around the top. some force will be needed
    • If all is going well, you will hear the sound of adhesive releasing and your opening device will slide further underneath
  • If you've made it this far underneath the battery, the temperature has likely cooled down significantly. So, keeping the opening tool inside, you'll be heating the battery again. This may deform your opening tool if it is made of plastic, so use your least-favorite one
Aggiungi Commento
Once again, heat the battery area uniformly until it is warm/hot to the touch Insert a second opening device around the area of the first, but moving towards the corner of the battery, in an attempt to begin separating from the side Push your opening tools as far as you can and pry upwards. Repeat the heating process if necessary, and with enough love and care, the battery should release. In the third picture, you can see the areas that adhere the battery to the case
  • Once again, heat the battery area uniformly until it is warm/hot to the touch
  • Insert a second opening device around the area of the first, but moving towards the corner of the battery, in an attempt to begin separating from the side
  • Push your opening tools as far as you can and pry upwards. Repeat the heating process if necessary, and with enough love and care, the battery should release. In the third picture, you can see the areas that adhere the battery to the case
Aggiungi Commento
On the old battery, fully remove the copper tape that grounds the phone. It isn't terribly delicate, but it is definitely breakable. My recommendation is to use tweezers, but careful fingers should be fine Even if it's bent, as long as it's still intact, it should work with the new battery. Once the new battery is inserted, place the tape over the contact and the screw inlet, and simply flatten the remainder of the tape against the battery
  • On the old battery, fully remove the copper tape that grounds the phone. It isn't terribly delicate, but it is definitely breakable. My recommendation is to use tweezers, but careful fingers should be fine
  • Even if it's bent, as long as it's still intact, it should work with the new battery. Once the new battery is inserted, place the tape over the contact and the screw inlet, and simply flatten the remainder of the tape against the battery
  • The phone may work fine without this piece of copper tape, as it appears to be used for grounding. I would not try this unless there are no other options
Aggiungi Commento
The new battery that I purchased fit very snugly inside the phone. Make sure that the battery is not bent while inserting, although you may have to apply some pressure to get it right inside. May the force be with you
  • The new battery that I purchased fit very snugly inside the phone. Make sure that the battery is not bent while inserting, although you may have to apply some pressure to get it right inside.
    • May the force be with you
  • With the new battery secured in place, you can now begin reassembly. With all of your previous experience, this shouldn't take more than 15 minutes at most.
Aggiungi Commento
Conclusione
Altre 28 persone hanno completato questa guida.
Mark
Membro da: 20/04/2012
2.496 Reputazione
4 Guide realizzate
ReImage Solutions Membro di ReImage Solutions
Business
1 Membro
4 Guide realizzate
Guide was precise to the point. Very well described. Thanks for this guide.
Laiju Joseph - Replica
Thanks a lot for the super detailed process. Amazing work. I was disappointed when sony service center refused to replace the battery of the phone, saying that this model is "non repairable". Your article gives me hope for my phone. I will look for a local technician as I'm not confident enough that I'll won't screw up my phone. Thanks again for this wonderful article
Varun Singh - Replica
Recognizing limitations is a big part of repair. At least having the information gives you an idea of what you're getting into.
Mark -
Just as perfect as any guide can be. I read it twice, and felt very confident that I can do it. Replaced the battery of ZL on my own, after Service Center refused. Feeling proud on myself, but again, it wouldn't have been possible without this guide. Thank you so much.
pawannahar - Replica
where can i get a new battery for xperia ZL?
chandrika selvaraj - Replica
I know this is probably no longer relevant, but for others your best bet is likely to use eBay. The price was medium-high in comparison to similar phones.
Mark -
Excellent, I have just now replaced and works fine!!!
Praveen Rao K - Replica
You don't need the heat gun if you pry carefully. Just don't put pressure against the inside of the screen. (Under the battery.)
Jeremy Turner - Replica
Jeremy's right, but I get the feeling he was very careful. The adhesive on the phone I worked on was fairly strong, and you can never go wrong with warming adhesive. Even if you only have a hair dryer, warming to 40-50 degrees Celsius can go a long way in preventing accidental damage. Lithium Polymer batteries should not be bent, as they can potentially explode (worst case scenario, but still).
Mark -
Thank you so much for the details on the explanation. I'm trying to replace the screen of my wife's ZL. Do you have more infrmation or suggeestions on any other guide or viedeos to check them as reference guides???
Thnaks again
Diego Garcia - Replica
There were very few resources available at the time that I created this guide. If you found some that were useful, it might not hurt to list them so that others can see them too.
Mark -
hi and thank you.......but the Loudspeaker Disassemble and is being hot....please help
mohammad khakpor - Replica
I apologize but this phone did not belong to me, and as such I can't do any real diagnostic. Internally, this phone could definitely get toasty if it was being used for games. The loudspeaker itself draws very little power, so check for any shorts while putting it back together. Other than that, good luck and list your solution if you find one.
Mark -
Hi Mark, i have two issues
1. During step.7, one screw i cant remove with the same screw driver i am using for all other screws.
2. i seem to have ripped off the ribbon cable you cautioned during step.8, is there any way out from this :(. Will the phone still work with reduced functionality with this cable gone ?
rajeshchittoor - Replica
Just perfect. Followed every step you mentioned and successfully replaced battery of my Xperia ZL. Its back to life after a year :-). Thanks a lot for the detailed information.
Rahul
Rahul - Replica
I wouldn't have been able to replace the battery of my Xperia ZL without this incredible detailed guide. Thank you!!!!!!
fbridger - Replica
Incredible detailed guide! Gave the ZL of my wife a second life. Now she hates me, because there's no need anymore for a new one! :)
Dennis Knake - Replica
Happy to ...be of service. I think. Carry on!
Mark -
This guide is stunning! I was worried if heating up the battery can be done without letting the whole thing explode (haha) but using a hair dryer and heating it up 4 or 5 times while using the guitar pick to slowly unstick the battery from the bottom (took about half an hour) works verry well. Take your time for this step! Reassembling was easy and my girlfriends phone is now working again. Mark you made two persons verry happy today. Thank you!
floh1111 - Replica
Thank you so much. Just finished it! (and suggested some additions)
ghschroder - Replica
Vielen Dank, mit Hilfe dieser präzisen Anleitung habe ich es tatsächlich locker geschafft, das XperiaZL zu reparieren! Alles Wichtige ist angesprochen bzw. bebildert, dann braucht es nur noch etwasZeit und eine ruhige Hand .
Nochmals vielen Dank !!!
Benno Colmorgen - Replica
BTW, does anyone know where the IR blaster is in this phone?
grvssl - Replica
I could be wrong, but it seems to be on the right side of the phone somewhere (power button side). I don't have the phone anymore to confirm. Look for a small hole in the side of the case. If it's not there, it would likely be on the top.
Mark -
After spending many hours dealing with you tube videos and incomplete/inaccurate information, I finally encountered someone whao knows what they are talking about. True---I could have run off to some tech expert to fix my problem---but isn't there more than enough of this kind of dependency? I would rather do it myself, then I would have the knowledge to apply next time, something I would not have if I turned to an expert.
cpr04862 - Replica
Thanks to your tutorial now my ZL is back on track. The only thing I screwed up was the notification light on the bottom. Do you know which connector I have to look for? Thank you anyway!
ImaVoodooChild01 - Replica
Thank you very much for this excellent guide. I've just changed the battery of my ZL for the second time using your instructions and everything went well. Great job!
Matthias Neutzner - Replica
any idea where can we buy original xperia zl battery?
Mukund Badi - Replica
Ebay or Aliexpress would be my first stops. It’s not a particularly new phone, so stock might be harder to come by
Mark -
Is the Copper strip on the battery required? I don’t have mine on the dead battery that was in my phone as I bought it used
Sricharan Saravanan - Replica
Grand merci pour ce guide pas-à-pas qui m’a été très utile: bonnes description/photos!
Thanks!
(Le seul soucis vient de ma “nouvelle baterie'“, elle ne vient pas de sony, et semble se décharger très rapidement!)
Julien Saveyn - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 9
Ultimi 7 Giorni: 37
Ultimi 30 Giorni: 180
Tutti i Tempi: 38,504
