Introduzione
This is the replace guide for Sony Xperia Z3 Dual as well as Z3 loudspeaker assembly.
Panoramica Video
Heat to soften back cover sticker. Place the suction cup and try to open a gap. Insert the guitar pick into the gap.
  • Heat to soften back cover sticker.
  • Place the suction cup and try to open a gap.
  • Insert the guitar pick into the gap.
Aggiungi Commento
Slide the guitar pick to cut the sticker and remove the back cover. Slide the guitar pick to cut the sticker and remove the back cover.
  • Slide the guitar pick to cut the sticker and remove the back cover.
Aggiungi Commento
Remove two screws by Philips screwdriver. Release all the connectors connecting with loudspeaker assembly. Remove the small vibrator securing bracket.
  • Remove two screws by Philips screwdriver.
  • Release all the connectors connecting with loudspeaker assembly.
  • Remove the small vibrator securing bracket.
Aggiungi Commento
Remove the securing cover. It's thin and weak, please be careful when remove it. Remove the securing cover. It's thin and weak, please be careful when remove it. Remove the securing cover. It's thin and weak, please be careful when remove it.
  • Remove the securing cover. It's thin and weak, please be careful when remove it.
Aggiungi Commento
Pry up the assembly and carry it out. Pry up the assembly and carry it out. Pry up the assembly and carry it out.
  • Pry up the assembly and carry it out.
Aggiungi Commento
Remove the loudspeaker assembly finally. Be careful with the flex beside assembly. Remove the loudspeaker assembly finally. Be careful with the flex beside assembly.
  • Remove the loudspeaker assembly finally. Be careful with the flex beside assembly.
Aggiungi Commento
Conclusione
Altre 4 persone hanno completato questa guida.
Sophia
Membro da: 25/03/2014
39.517 Reputazione
107 Guide realizzate
this is all good but is there a link to the part ?
morten hundevad - Replica
EBay search Sony z3 replacement loud speaker cost's around £3-£5
Martin Lb -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 43
Tutti i Tempi: 3,576
